speedo after 5.12 gear install?
  • 1455 Views
Offline airmanwilliams
  • 913
« on: January 03, 2011, 09:21:01 AM »
I just received two axles with 5.12 gears to put under my 87 samurai. One is a front samurai axle and the other is a hybrid rear housing. I have lost all calculater pm's ive received and was wondering if anyone can tell me how far off my speedo may be once I install these with 235/75R15 tires and a 3" spring under lift? I have the stock tcase for now but hope to trade my two stock axles for a lower geared tcase soon.
Also for a very mild wheeling rig that is a daily driver what would be the best tcase gear set up to use? I plan to just go as big as 31's.
1993 4door Suzuki Sidekick JX
Re: speedo after 5.12 gear install?
« Reply #1 on: January 05, 2011, 12:31:23 AM »
Here you go:
http://www.solemnwarning.net/transmission/?id=53
Already programmed for you. With the 5.12 gears you are pretty much in line for 31" tires already.  I wouldn't go lower then a 4.8:1 kit myself.  But you can change the transfer case in the transmission calculator, it has most of the after-market SJ series transfer cases in there.
Offline my996duc1
  • 222
« Reply #2 on: January 13, 2011, 10:58:39 PM »
here is a good online gearing calculator that you can run a couple setups side-by-side to compare them.
http://www.grimmjeeper.com/gears.html
Here is another one that I have used.
http://www.lepayne.com/gears.html
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
  • 913
« Reply #3 on: January 14, 2011, 05:18:38 AM »
I appreciate it guys thank you.
Offline z3ro
  • 339
« Reply #4 on: January 15, 2011, 11:05:44 AM »
There's a really crude way to do it.  Have someone go 20 or so down a straight road.  Pace them, and then move your needle the the speed they say they are going.
Of course, use a stock car.  I used my GPS for a round-a-bout estimate of how off I am, then moved my needle.
