here's some poser pics of it somewhere other than the shop. then some camping prep.(back in the shop). and finally a day I have waited a long time for.........the decal.
The ones on the back window? Sweet
Those pictures make me want a 4-door. I kind of wish I did, because there's nothing worse than seeing a 4-point buck and trying to get 4 people bailing out of the 2 door Tracker. Yours looks awesome. Just the right height, track width, tire size, everything looks well-proportioned.
I especially like the transmission hump, you eliminated all the carpet and plastic stuff and it actually looks damn good, those cup holders are a great idea too. I have a couple old big speaker magnets that I may consider for something like that. Maybe you should patent your idea. Speaking of which...
mag-light over the driver door
Dammit. I knew I should have patented that
I found out that if you pull out those two gray plastic plugs, there are actually nuts welded in for the option of adding a handle there. I guess that would be for right-hand drive vehicles. Anyways, perfect fit for two M6x1.0 bolts, a little aluminum plate with the bolts countersunk into the rear of the plate. The nuts are on the front side of the brackets and have just the perfect clearance for the flashlights.
The reason for the radius on the top leading edge was because the roof started to curve in drastically there, and cutting it was easier than making it contour to the ceiling.
The only trick is...being 6'2" tall, that I need to watch my head. I only bumped my head once, needless to say, I learned quickly to duck my head.
