newbie just bought a 94 samurai, just needa little help
  • 9 Replies
  • 1335 Views
« on: December 20, 2010, 08:17:05 AM »
as the title says, i just bought a 94 samurai.  took the train out to Iowa on Saturday and drove her back to Michigan yesterday.  She ran like a champ the whole way home.  It just has two small issues that I'd like to fix right away, and I was wondering how much trouble it will be for me to do these myself.
Problem 1:  the speedometer stopped working shortly after i started driving home.  My best guess is that the cable broke.  since cables are pretty cheep, I ordered one today.  if that doesn't fix the problem,  what else could cause the speedometer to stop working aside from the possibility that the gauge itself went bad.
Problem 2:  the blue indicator light for my high beams stopped working, what are some reasons for that to happen?  The high beams still work, I just feel like a jerk when i don't realize they're on and someone is coming towards me.
Re: newbie just bought a 94 samurai, just needa little help
« Reply #1 on: December 20, 2010, 12:39:58 PM »
These rigs are pretty simple, if it's not the cable or a broken gauge then the only thing left is the gear in your transfer case.  The speedometer went out on my SJ as well, I just use a GPS instead.
For the high beam light it is probably a bad light bulb.  The only other reason it would go bad is if you lost ground somewhere, but I would try the light bulb first.
« Reply #2 on: December 20, 2010, 01:06:34 PM »
Thanks, how difficult is it to get the dash apart?
« Reply #3 on: December 20, 2010, 07:20:31 PM »
Not very.  I believe it is just the four screws on the dash and it pulls forward.
« Reply #4 on: December 21, 2010, 08:49:06 AM »
excellent,  i should have time to get everything done this weekend.  hopefully i won't have to post any more questions.  thanks for your help.
Offline tipover
  • 422
« Reply #5 on: December 21, 2010, 09:16:38 PM »
On the earlier round venter dashes which may be the same as the later square vent dashes, to pull the instument panel, yes you need to remove the 4 allen head bolts and because the hazard lights switch sticks up in the way and may break, drop the steering a little bit.  This is done by removing the plastic part of the dash under the steering column and loosening the 2 torx bolts that holds the column just enough to clear the haward switch.
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
« Reply #6 on: December 27, 2010, 05:53:37 AM »
thanks for all your help.  I picked up a "universal" speedometer cable and found out last night, that it's not so universal.  no big deal, i just ordered a cable that was made for a samurai and hopefully i'll have it before the weekend.
i have another concern that i noticed this weekend,  it feels like i've lost a lot of horsepower since i bought it.  I could just be crazy and didn't notice the lack of power on my drive home.  but, my acceleration is lousy up until about 3000 rpm (i'm guessing since i don't have a tach).  once i hit that point she'll pull me back into my seat.  also, if i'm going 70 mpr on flat road i can't hold speed in 5th gear.  I ran a diagnostic, but the only code that pulled up was for the speed sensor.  what could be causing the loss in hp? or am i just nuts?
« Reply #7 on: December 28, 2010, 05:10:10 PM »
There are a couple of things.  The first to do is a full tune-up since you just got the vehicle.  Cap, rotor, plugs and wires.  Next would be to check the timing.  If your timing is to far back you will see a loss in power at lower rpm's.  One way to check is to mark where your timing is at currently, then try advancing it slightly and going for another test run.
« Reply #8 on: January 03, 2011, 06:14:59 AM »
it's alive!
all i needed to do was adjust the distributor, she runs like a dream now. still did a tune up to make sure.
« Reply #9 on: January 05, 2011, 12:16:51 AM »
Nice!  :)
