Engine and Tranny Swap
  • 1346 Views
Offline Wildtire
  • 19
  • Tried and True Automotive
« on: December 18, 2010, 08:07:46 PM »
Are there any Transmissions that have the same spline on the tailshaft? Thinking about what to do for an engine swap and maybe tranny and T case if needed. Not even remotely interested in a 1.6 or a TDI.
Keep Coming Back!
Offline tipover
  • 422
Re: Engine and Tranny Swap
« Reply #1 on: December 19, 2010, 08:34:29 PM »
The only thing that I know is that the kick and sammy transmissions have 23 spline out outs.  I don't know if anything else has the same spline.
hopw that helps.
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
« Reply #2 on: December 19, 2010, 08:54:01 PM »
The kick 2wd transmission have the same output shaft.  But you can just make a custom jack shaft with just about any 2wd transmission and run it to the engine.  Any drive-line shop should be able to put it together.
Offline Wildtire
  • 19
« Reply #3 on: December 30, 2010, 05:13:01 PM »
Word... Thanks!
Keep Coming Back!
« Reply #4 on: December 31, 2010, 11:35:50 AM »
Do an rotary swap!  Those look like fun.  :)
Offline Wildtire
  • 19
« Reply #5 on: January 24, 2011, 08:02:42 PM »
New Colorado Emissions aren't being nice to any engine swappers, so it's gonna be an 8 valve 1.6 with a GM throttle body and ecm, with a stock airbox. They won't even know what just rolled past em!
Keep Coming Back!
Offline jrbblack93
  • 26
« Reply #6 on: February 01, 2011, 08:40:38 AM »
you can do the swap with the chevy V6 vortech engine from rocky road outfitters.
you can look  it up at http://www.rocky-road.com/vortec.html its pretty expensive but if you have the money and the time to do it and the tools it will pretty beast.   8)
