Leaky rear axle
  • 1046 Views
Leaky rear axle
« on: December 10, 2010, 04:11:26 PM »
Our left rear axle on our 2000 4x4 GV has been leaking gear lube slowly for some time.  Finally decided this should stop and took it apart - pics attached.  Anyway, I thought I'd replace the axle seal, but that goes into the axle quite a bit; obviously something quite outside of that is what's actually leaking.  Looks like I'd need some permatex (1) between the end of the axle and the baseplate for the brake hardware and (2) around the back of the four-bolt 'seal' that goes around the back of the baseplate.  It looks like this four-bolt plate should allow 'extra' gear oil to be flung off the axle/bearing and drain back into the axle housing to the center diff.  I can't find anything on this in my manual. Can someone verify this is correct or if I need to seal something else?  Does the axle seal really need to be replaced?  TIA ~
GH aka Dan
« Last Edit: December 10, 2010, 04:14:45 PM by Green_Hornet »
Offline IanL
  • 466
Re: Leaky rear axle
« Reply #1 on: December 11, 2010, 01:23:59 AM »
Hope this helps:
Re: Leaky rear axle
« Reply #2 on: December 11, 2010, 07:02:04 AM »
Thanks, no talk of sealant at all.  There was oil everywhere in the drum, I'm putting new shoes on because of it.  Sorta surprised the drum brakes worked well at all (e.g., parking brakes).  That said, I'm hoping that shiny surface on the inside of the tire goes away for good!
Offline Novadon
  • 205
  • South Carolina. USA
Re: Leaky rear axle
« Reply #3 on: December 11, 2010, 07:25:34 AM »
Yes, there is a sealant required between the brake backing plate, bearing retainer and axle tube end.
It's all in here...   ;)
http://www.suzuki-forums.com/1g-1999-2005-vitara-grand-vitara/19396-has-ne1-here-pulled-rear-axle.html
Max (AKA Novadon)
« Last Edit: December 11, 2010, 07:28:28 AM by Novadon »
03' Honda Odyssey
Offline Toy Box
  • 222
  • 00 Grand Vitara
Re: Leaky rear axle
« Reply #4 on: December 11, 2010, 08:54:37 AM »
Great write up Max
You Play you Pay
Offline Novadon
  • 205
Re: Leaky rear axle
« Reply #5 on: December 12, 2010, 05:47:20 AM »
I used RTV (blue) as a sealant. It has been several years now and no problems.
I actually think that my leak originated from the sealant / flange area from the get-go, as the inner axle seals looked fine, as did the axle / seal contact area. I replaced the seals anyways.
03' Honda Odyssey
Re: Leaky rear axle
« Reply #6 on: December 15, 2010, 08:45:16 PM »
Studly, Max, and thanks for all your posting work!
« Last Edit: December 15, 2010, 09:19:53 PM by Green_Hornet »
