Work Continues..
Scrap everything down to gain easy access to the chassis for drilling.
I had to drill six 12mm holes through the angled steel and chassis. My had got stabbed, twisted and cut quite a few times while drilling, blasted radiator! Three different sized drill bits were used to make the 12mm holes, each one slightly larger than the other.
The two front bolts..
You can see the 3 bolts here. A 4th bolt is to be added later on for extra strength.
In the 2nd pic, you can see that the 6" wide flat steel was slightly too long. Since I don't have access to a chop saw or cutting torch, I had to cut through the entire thing with a hack saw! Talk about sweat!
Bumper installed and fitting nicely so far. Drilling through those 2 angled pieces of steel and the flat steel was a real PITA.. I started to smell the windings heating up in one of my drills!
Test fitting the old winch mount. You can see that I already cut off its lower section.
Now time to get it welded.
Now that's a big welding plant! I got a contractor to assist me here..
Fire away..
This is where I am at so far. Time for some primer and paint, DIY style.. I have a little neatening up to do here and there so it has both looks and performance..
