Vibrations after SPOA???????
  • 20 Replies
  • 4507 Views
Re: Vibrations after SPOA???????
« Reply #15 on: December 19, 2010, 09:04:23 PM »
Instead of a spacer you might want to look at extended slip yokes.  That way your drive-line will have a better angle but you can still get the extra distance you need.
How close is your drive-line to falling apart?
Offline samuride1
  • 42
« Reply #16 on: December 25, 2010, 09:07:54 PM »
Driveshaft is in phase. The slip yoke has about 1.5" of travel. It has a SS but I havent thought about that!!!! Will definitely check that out. I ruled out the front end when, like a bone head, I removed the front DS. When I removed the front DS i was willing to try anything before I actually thought about it! LOL
The tires are 31x10.50r15 BF Goodrich A/T's 6 ply tires. They are pretty stiff with 40 psi in each tire. I will drop pressure to at least 30 psi. It will at least "soften" the ride a little.
Thanks for all of the good info!!!!
Offline Jluck
  • 1389
  • 40
« Reply #17 on: December 25, 2010, 09:33:48 PM »
40 PSI!!!!!!?????? did you go to Les Schwab or something? I would go down to 22-25 on a rig that light. that should help a bunch.
Offline samuride1
  • 42
« Reply #18 on: December 26, 2010, 08:28:23 AM »
I didnt understand that myself ??? Why would anyone put that much air pressure in a tire on a vehicle that light??
Offline ASI H8
« Reply #19 on: December 26, 2010, 06:55:57 PM »
In order to remove fillings.  :laugh:
« Reply #20 on: December 28, 2010, 06:11:54 PM »
If you have a light truck tire most tire shops will fill it to the recommended pressure on the tire, ignoring the recommended pressure on the vehicle.  This is a carry-over from the Firestone debacle where the recommended tire pressure on the Explorers was set too low and caused tread separation.
« Last Edit: December 28, 2010, 06:20:39 PM by Drone637 »
