1.6L Need some timing help!
  • 22 Replies
  • 3293 Views
Re: 1.6L Need some timing help!
« Reply #15 on: December 10, 2010, 08:16:47 AM »
There is a notch that the fan belt pulley fits into that I think you can see,
that also lines up with the mark on the cam belt cog
Offline ender06
  • 74
« Reply #16 on: December 10, 2010, 08:18:12 AM »
REALLY? Um sorry to be ignorant, but can u explain where the mark would be, where to look? Thanks
« Reply #17 on: December 10, 2010, 08:18:30 AM »
There is a mark on the lower timing belt cog....you can't see the mark without taking the crank pulley off.
There is also a mark on the actual crank pulley (the one the ribbed belts fit on).  It is on the outside lip of the inner pulley....you line up the mark with the 0-20 scale on the timing belt cover (line it up with the zero mark to set the engine at TDC on either cylinder #1 or #4).
Offline ender06
  • 74
« Reply #18 on: December 10, 2010, 08:24:17 AM »
AWE! Skyhiranger, thanks a ton! U will save me alot of time! THANKS Im gooing to look now
« Reply #19 on: December 10, 2010, 08:26:25 AM »
Look into the end of the crank where the pulley bolts on, the notch keeps the pulley
from being put on wrong, it only fits one way.
You will need a mirror, or remove the radiator to see it, in fact I remove the radiator just
so I can get at the big crank bolt with an impact, I have an auto trans, so I can't put it
in gear to stop the crank from turning, which makes the bolt difficult to remove.
Offline ender06
  • 74
« Reply #20 on: December 10, 2010, 08:31:53 AM »
OK, so.......... Will this work to get the timing belt in the right spot? Line the crank pulley up with the mark at the 0* mark on the cover. Then Line the Cam pulley up with the "E" key down and the outter "E" mark at the notch on the valve cover.
« Reply #21 on: December 10, 2010, 08:38:22 AM »
If the timing belt cover is on, if not, the cog notch points at 12 o'clock
and the cam mark point's to 6 o'clock, but I'm not sure on which mark
to use on the cam sprocket, it's been too long.
This configuration is firing #1, and the distributor should be pointing at
about 5 o'clock position on an 8V engine, I haven't don't enough with
the 16V engine to be sure about the distributor position or the cam
sprocket position, it might be the same, but I'm not sure
Offline ender06
  • 74
« Reply #22 on: December 10, 2010, 08:42:12 AM »
Yeah the timing belt cover is still on. I know EXACTLY where the cam pulley marks go, I just cant get the cover off to see the crank marks. Thats my dilema.
