2000 GV rear bump stops
  • 863 Views
« on: November 25, 2010, 09:43:52 PM »
Does any one know what size the studs are(thread size&pitch)on the rear bump stops on a 2000 GV. I'm looking to fab up some 2" spacers to install at the same time I install the lift and other parts I have been collecting. Thanks for the info.
Offline r3cc0s
  • 321
Re: 2000 GV rear bump stops
« Reply #1 on: November 26, 2010, 01:54:24 AM »
wow, I just installed the 1.5" spacers from bits4vits just last night... but I didn't measure the size or record the thread type....
I'd suggest maybe send them an email?
Offline r3cc0s
  • 321
« Reply #2 on: November 26, 2010, 02:08:47 AM »
The bump stop is held in place by a M10 retaining stud. The retaining stud needs to be shortened to 10mm long. The spacer then threads on to the standard bump stop. The supplied M10 x 25 studs are then threaded into the spacer and then re-installed in the vehicle.
This was from a previous thread
« Reply #3 on: November 28, 2010, 08:44:45 PM »
Thank's for the info.Now I just need some good weather so I can start the transformation(I have no shop to work in)When I get started I'll post some pics. Thank's again for the info.
