Incase anyone wants to know... The '98 Sidekick's evaporator box and evaporator fit the X-90. All the electrical connectors are in the X-90's wiring harness too.
I wanted AC in my X-90 so I grabbed the evap box from the '98 Sidekick at the junkyard today. I figured if I'm going to have the dash apart I might as well put AC in it. Turns out it's a very easy thing to add AC to these cars. I bet the compressor on the v6 is going to be oversized for the evaporator. I'll have to charge the system with gauges and watch the pressures to figure out the correct capacity of freon to put in it. It's going to get cold quick that's for sure. Just in time for winter? o.O
I love how interchangeable these things are.
I just scored a '99 Tracker for free that runs great. I also have an '02 4-door ZR-2 v6 Tracker as my daily driver. If anyone remembers, I just put a used engine in it last winter. What I intend to do is pull the ECU, wiring harness, and engine from the '99 and put it in the '02. Since it's just a daily driver the 4 cylinder will be fine. The '99 is automatic so I'll have to use that transmission. Alot of work but this frees up that v6 to be used in the X-90.
Saves me $1000 and get's this project moving.
(Why does this forum freak out when I type? It keeps scrolling up?) >.<
