What type of oil to use with 6.5:1 gears.
  • 11 Replies
  • 2283 Views
Offline Jordan
  • 161
  • Chrome don't get ya home, but it sure looks nice!
« on: November 22, 2010, 09:23:20 PM »
Hi, what kind of oil do you guys use in your tcase with 6.5:1 gears.
Thanks.
82 SJ410: 5" lift (spoa), home made cross over steering, bestop, custom rust lots of it,33"tsl, 6.5:1's. To install: Toyota diffs being built. To build: roll cage, traction bar, bumpers.
89 sidekick: lift 2"suspension 3"body, 31's, aluminum rims, warn hubs, (4) lights on roof, turbocharger.
Re: What type of oil to use with 6.5:1 gears.
« Reply #1 on: November 22, 2010, 11:06:49 PM »
I just use the standard 80-90 weight.  If you put all new bearings and seals in when installing the gears you can switch to a synthetic.  If you have been running it a while I would stick with the 80-90.
Offline Jordan
  • 161
« Reply #2 on: November 23, 2010, 08:15:34 AM »
Its a rebuilt tcase from RRO, I just got it bolted in, its never had oil in it yet. So what type of synthetic oil should I use?
Thanks Drone.
« Reply #3 on: November 23, 2010, 11:53:15 AM »
I've use the 75W90 synthetic without issues, it should work fine for the transfer case.  Beware though, it is a bit more expensive.
Offline Jordan
  • 161
« Reply #4 on: November 26, 2010, 08:52:00 PM »
OK, thanks Drone. I can't wate to try out the low range ;D
« Reply #5 on: December 01, 2010, 11:51:50 AM »
Did you get a chance to test it out yet?
Offline Jordan
  • 161
« Reply #6 on: December 01, 2010, 04:45:14 PM »
Yes I did, its awesome 8) I went over some rocks at a idle with no problem, before I had to work the clutch a ton, but when I tried some bigger stuff I broke the four bolts on my cross over steering arm :o I guess the 33s put it under allot more stress then the 205s, so time for some high grade bolts, and if they brake I'll drill it out for bigger bolts.
« Reply #7 on: December 01, 2010, 05:59:10 PM »
Is your high steer arm connected to the kingpin?  If so that isn't going to work, you need to brace it off of the caliper.  When I bought my SJ someone had done the same thing, I though it was the low grade bolts so I swapped in high grade ones.  Then I snapped 3 high grade bolts off dropping of a ledge on the Moab Rim trail.  Not the best trail to drive down with only being able to turn to the right.  :D
I recommend picking up stage 1 of the high steer kit from Sky Manufacturing.  It's what I run on mine, bit expensive but worth it:  http://www.sky-manufacturing.com/new/detaproduct.php?id=178
You can also find an older Mercedes and snag the arms off of it if you want to try and stay as cheep as possible.  http://www.zukiworld.com/forum/general-suzuki-forum/samurai-high-steer-info-needed/ for more details.  :)
Offline Jordan
  • 161
« Reply #8 on: December 03, 2010, 07:38:15 PM »
Yes it bolts to the kingpin, it has drums so I don't have a caliper to bolt it to, but I'm looking for sami diffs to put on it so I can get a stage 2 high steer kit
« Reply #9 on: December 04, 2010, 12:44:52 PM »
Drums?  Is this an SJ-410 then?  The Samurai knuckles should fit on the SJ-410 axles.  I may be off a bit, as my SJ-410 already had disk brakes on the front when I bought it.
Be careful when switching to Samurai axles.  You will need to weld on new pads.
Offline Jordan
  • 161
« Reply #10 on: December 04, 2010, 09:36:29 PM »
Yes its a 82 SJ-410, 83 and up have front disc brakes.
I'll make sure I weld on new pads, thanks.
« Reply #11 on: December 06, 2010, 02:30:47 PM »
On the passenger side your pad will be sitting partially on the center diff.  Your u-bolt won't fit quite right as it will try and slide up the side of the diff unless you put a bend in it, I finally welded a chunk of metal to act as a guide for the u-bolt to help it stay in place.
