Idling question
  • 21 Replies
  • 3137 Views
Offline Asbury030
  • 85
Idling question
« on: November 10, 2010, 11:29:52 AM »
Well my question is When my samurai idles it will sounds like it is gonna cut off but doesnt and it keeps doing it on and off.... What could be my issue? Its a 1990
Offline Asbury030
  • 85
Re: Idling question
« Reply #1 on: November 10, 2010, 12:43:42 PM »
Any ideas.... I will hold the gas down a little bit and it will go up and down reving.... I dont have to much gas in it could this be the problem or something bigger? I did notice it until I put the doug thorley exhaust and got all the exhaust done.
Offline Asbury030
  • 85
Re: Idling question
« Reply #2 on: November 10, 2010, 01:56:37 PM »
Also I changed the spark plugs, wires, Pcv valve, oil, oil filter, and air filter all today... but was doing this before I did all this.
Re: Idling question
« Reply #3 on: November 10, 2010, 05:28:51 PM »
A little water in the float bowl can block the jets, back and forth
causing this hunting idle problem
Offline Asbury030
  • 85
Re: Idling question
« Reply #4 on: November 10, 2010, 05:35:29 PM »
Float bowl?
Offline DonD
  • 140
Re: Idling question
« Reply #5 on: November 10, 2010, 05:43:20 PM »
My '90 Track was doing that, turned out to be a loose and missadjusted TPS.
Central AZ
'90 Tracker
8k Smitty Winch
Man. hubs
Skids
Nerfs and sliders
Lockrite rear
OME susp
4.24 TC
ZOR Ft Bumper
Re: Idling question
« Reply #6 on: November 10, 2010, 05:44:42 PM »
Is it injected or carb?
I'm not sure what year started EFI
Offline Asbury030
  • 85
Re: Idling question
« Reply #7 on: November 10, 2010, 07:19:31 PM »
It's EFI... I was thinking it was the O2 sensor... Didnt start untill I pulled that one out and put it in the new doug thorley. I've noticed at the end of my tailpipe spits out water or so I think it is water
Offline Asbury030
  • 85
Re: Idling question
« Reply #8 on: November 10, 2010, 07:29:21 PM »
What do you mean by misadjusted?
Re: Idling question
« Reply #9 on: November 10, 2010, 07:42:19 PM »
Ya, I found a bad O2 out of the box, take it back and have them replace it
Offline Asbury030
  • 85
Re: Idling question
« Reply #10 on: November 10, 2010, 07:46:07 PM »
Oh I used the stock one that came out of the factory...guess it went bad? It looked pretty black and nasty
Offline Asbury030
  • 85
Re: Idling question
« Reply #11 on: November 10, 2010, 08:29:01 PM »
I appreciate the help by the way... I will let you know how the new O2 sensor works out
Re: Idling question
« Reply #12 on: November 10, 2010, 08:44:31 PM »
Remember that the O2 sensor is farther away from the engine and it
takes much longer to heat up, which it needs to be hot to work right,
so drive the truck get it hot and see if the problem continues.
BTW The OE sensor I replaced was still good at well over 200K
miles so don't buy a new one just yet.
Re: Idling question
« Reply #13 on: November 10, 2010, 08:48:26 PM »
Water is normal in a first started up car, the exhaust pipe condenses the water vapor
in the exhaust until it gets so hot that the vapor no longer can condense. For every
gallon of gas you burn, a gallon or more of water in vapor form comes out of the exhaust.
Look at a car on a very cold day, you see it back east all the time in the winter
Offline tipover
  • 422
Re: Idling question
« Reply #14 on: November 11, 2010, 09:04:20 AM »
I had the same problem when I put a header on my kick motor.  I dont see EFI sammys in CA very often, but I have dealt with many kick motors.  I believe the idle system of the sammy is like the 89-90 kick.  you have changed the air flow characteristics so the idle control valve or selanoids out side it normal limits.  If it is like the 89-90 kick you can adjust the mechanical stop on the throttle plate.  this will allow the vavle to be in the middle of its range.  If it is like the later kicks, you dont mess with the throttle plate, but it has an adjustment screw to adjust the duty cycle.
I doubt that the TPS all the sudden went out of adjustement when you changed the exhaust.  if O2 sensor is bad, i think that it would just go into limp mode, but weirder things have happened.
let us know if this works.
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
