1998 Suzuki Sidekick Sport Build
  • 10 Replies
  • 8411 Views
Offline Dennis .89-
  • 54
  • I Owe I Owe, So Off To Work I Go!!
« on: November 04, 2010, 09:46:23 PM »
http://www.cardomain.com/ride/3886352/1998-suzuki-sidekick-sport-jx-utility-4d-edmonton-ab-ca?p=1
This is my 1998 Suzuki Sidekick Sport 4 Door Build hope you enjoy
as off 11/4/2010
let me know what you think.
Dml
Re: 1998 Suzuki Sidekick Sport Build
« Reply #1 on: November 06, 2010, 07:34:07 AM »
Looks good.  You should post a couple of your photo's here, for others.
I installed a set of Bombz seats in my tracker.  They just barely fit with the wider console I am using, but seem to be very comfortable to set in and hold you in place better.
Offline z3ro
  • 339
« Reply #2 on: November 06, 2010, 01:43:26 PM »
The rig looks good!
The only thing very wrong are your seat mounts.  The way you have it is completely unsafe.  If the rig never sees pavement then no worries, otherwise I would change it.  Those bolts aren't near thick enough to withstand the pressure that would be on them on an accident.
Offline Dennis .89-
  • 54
« Reply #3 on: November 06, 2010, 06:12:13 PM »
Yea i love the seat's there very soft and hold you in place very well even in tight corners or going down steep drops i love them
which bolts were you referring to? the ones going though the circular aluminium Spacer?
Offline z3ro
  • 339
« Reply #4 on: November 07, 2010, 01:56:34 AM »
Yes, those spacers aren't safe.  Like I said if you only drive it offroad, no worries, otherwise I'd change it.
« Reply #5 on: November 07, 2010, 05:41:20 AM »
As it appears you are using the seat mounts for your seat belt/4 point mounts, you might want to strengthen it up with some cross braces also.  Safety harnesses should be mounted to roll cages or through the body, and the seat mounting bolts (to the body) are not near as strong as factory seat belt mounting bolts.  Is the board for spacing also?
(Just trying to help you stay safer, these darn things can even roll over right behind your house.  And it helps if you are using the 4 points then.)
I cut down the outside Zuki mounts, and mounted the rails on other side direct to Bombz seat mount, and I am using stock seat belts mounting points.  I had to go back and add another mounting pad where it bolts to car, so I could move it outwards.  (my new console was just a little wider.)  http://www.zukiworld.com/forum/build-diaries-how-to-diy/install-new-seats-93-tracker/  When that is your complete safety system, you don't want coming apart.
« Reply #6 on: November 07, 2010, 11:34:05 PM »
Where did you get the logo and how much did it run?
Offline Dennis .89-
  • 54
« Reply #7 on: November 20, 2010, 03:46:31 PM »
i made it my self
with soem plexy glass and sand paper and a few blue leds
Offline Jluck
  • 1389
  • 40
« Reply #8 on: November 21, 2010, 07:18:52 PM »
I want them tracks. I'm shopping for some right now. are they available? what brand are they? send pm ;D
Offline djlantis57
  • 871
  • Take your chrome home
« Reply #9 on: November 22, 2010, 11:46:36 AM »
Better yet, post here if you find them...I'm curious too.  As if I really need to be shopping for tracks anyway  ::)
Offline jamoffroad
  • 15
« Reply #10 on: April 13, 2011, 07:21:11 PM »
all the body mods and all anyone wants to know about is the seat mounts??????  thats crazy the body trim on the rockers is cool ,but did it hurt the body structer? very cool tracker love the body triming...
91 kick  convert
