95 Kick biuld for under $500
  • 18 Replies
  • 5416 Views
Offline JNM78
  • 14
  • " I like mud"
Re: 95 Kick biuld for under $500
« Reply #15 on: October 22, 2010, 04:17:13 AM »
 I'm trying to build a set of skid plates, my biggest problem is getting mud into the bell housing, it's causing my clutch not to fully engauge. have to spray it out with water (P.I.A.)
 I'm going to the local surplus store to find some alum. or metal sheeting today, lets see if I can get this one done and still be under budget.
Offline meach4x4
  • 59
« Reply #16 on: October 22, 2010, 12:07:49 PM »
You may want to use steel, instead of aluminum.  Aluminum is lighter, but it has a tendency to stick to rocks.  In fact, they use aluminum for the grips in some wading boots.  I found out about this when I had an aluminum drift boat and had to keep a coating (Gluvit) on it to keep it from hanging up on the rocks.
Of course, you could use Aluminum and coat it with Gluvit, but I would be a lot cheaper to just use steel.
Meach4x4
Offline jawman
  • 406
  • 1234
« Reply #17 on: October 30, 2010, 08:46:19 PM »
you could make your own coil spacers to get 1-2'' lift depending on how big you make the spacers. Just find some polyurethane and cut 4 "donuts" out. you can get the stuff at Mcmaster Carr on line.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline vw505
  • 133
« Reply #18 on: November 03, 2010, 08:35:55 PM »
good build
