Torque wrench
  • 26 Replies
  • 4568 Views
Offline jawman
  • 406
  • 1234
Torque wrench
« on: October 02, 2010, 10:52:47 AM »
I know easy thing to find, but I cant seem to find one. I have an old school 1/2 drive needle style torque wrench that works, but only reads ft lbs. I relized I need a inch lbs. torque wrench to finish putting my motor back together. the only thing I found that has the right torque range is a 1/4inch drive. where do you think I can find one?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Re: Torque wrench
« Reply #1 on: October 02, 2010, 11:42:41 AM »
Most 3/8" drive torque wrenches are calibrated in inch pounds.
Try your local auto parts store tool section
Haptown
Re: Torque wrench
« Reply #2 on: October 02, 2010, 03:31:53 PM »
Or look for a 1/4" one for those bolts that need only 5-8ft/lbs.
HarborFreight has both the 1/4" and 3/8".
Offline jawman
  • 406
  • 1234
Re: Torque wrench
« Reply #3 on: October 02, 2010, 06:45:15 PM »
I have found a lot of torque wenches, but the torque range is wrong. the 1/4 drive from harbor fright says 20-200 inch lbs, but all my hexhead bits are 3/8 drive. the 3/8 drive is 5-80 inch lbs. and a lot of the torque specs. are higher then 80.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline Medford
  • 184
Re: Torque wrench
« Reply #4 on: October 02, 2010, 07:31:22 PM »
I had the same type of problem, and solved it at Schuck auto by buying a set of adaptors for 4 or 5 bucks that convert my half inch drive stuff to 3/8 or 1/4 and also the reverse.
Re: Torque wrench
« Reply #5 on: October 02, 2010, 07:56:47 PM »
Or you can get all three sizes of torque wrench, 1/4, 3/8ths and 1/2. I know their expensive but they are worth every penny, especially if you do a lot of work.
Re: Torque wrench
« Reply #6 on: October 02, 2010, 08:07:49 PM »
I have 2 torque wrenches....one 1/4" drive that is in inch pounds and one 1/2 drive that is in ft.lbs.  Then I have a set of adapters that I convert to 1/4, 3/8, or 1/2, as needed.  I bought everything at Harbor Freight.  If you catch the wrenches on sale, you can pick them up for between $12 and $25.  The 1/4 one will be the more expensive one, ironically.
Offline Trackerprts
  • 106
  • Aiirbag
99 Tracker pieced together out of 3 cars.             RR Body and suspension lift ,31 10.5r15
winch bumper,rock sliders
Offline weldboy
  • 91
  • I'm only here for the carnival atmosphere !!!
Re: Torque wrench
« Reply #8 on: October 03, 2010, 10:34:17 PM »
Snap On, Mac, Matco Tools    Pricey but good stuff !!!!
Offline jawman
  • 406
  • 1234
Re: Torque wrench
« Reply #9 on: October 04, 2010, 09:12:32 AM »
I guess I will ju8st go with a 1/4'' on for now. thanks for the replys
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline ranger88den
  • 279
Re: Torque wrench
« Reply #10 on: October 05, 2010, 03:39:22 AM »
Recent Harbor Freight ad in my area (NW Ohio).  Expires 10/28/10.  Hope you can use it.
Re: Torque wrench
« Reply #11 on: October 05, 2010, 05:27:25 AM »
That is a hell of a price on that wrench.  I don't think I have ever seen them that low.
I don't know that they will let you use printed coupons though...since those are hardcopy coupons and not email/online coupons...but it would be worth a shot.
Re: Torque wrench
« Reply #12 on: October 05, 2010, 05:42:39 AM »
I don't know that they will let you use printed coupons though...since those are hardcopy coupons and not email/on-line coupons...but it would be worth a shot.
If you order on-line, you put the PROMO CODE from your coupon in the coupons spot and they will give your the credit,  You can also find Coupons on line that they honor.  On-line, and probably in the store, they will only allow one Coupon for each purchase.
I find Harbor Freight tools to be a good value, and use their 1/2" torque wrench.
Re: Torque wrench
« Reply #13 on: October 05, 2010, 05:49:20 AM »
But don't they charge you shipping?  By the time you pay that you are probably better off just going into the store...or wait until they run it on sale....either online or in the store....stores will generally match the online price, if it is lower.
I have a lot of HF tools...people like to cuss them as "one time use" tools....but they have all held up very well compared to what I would have spent buying craftsman, mac, snap on, etc.  I have broken very few, and the ones I have they replaced without hassle.
Offline ranger88den
  • 279
Re: Torque wrench
« Reply #14 on: October 05, 2010, 08:33:26 AM »
Couldn't hurt to try the coupon at a local store.  What have you got to lose?
