You have given me a fresh idea of going in for a 4-Link for just the rear and keep the front in SPoA setup. What would be the advantage of this? One thing I can think of is the added complexity of Coil Over in the front (with steering setup). Right?
The main reason we did this swap was I kept bending up my rear springs. Originally we were going to build a traction bar. After looking at the amount of work we decided to just go all the way and build a full 4-link.
The front is actually easier then the rear as far as design. You need your lower two links, an upper link to keep the axle from rolling, then a track bar that is as close to even wit your steering arm in length and positioning as possible to keep the axle from shifting left or right. Since you are using a track bar to keep your axle from shifting left or right you don't have to worry about triangulation near as much as you do with a 4-link in the rear.
For the lower links a lot of people just put a Y on one or both sides.
6 - 7" of lift from stock. So, this would basically mean as high as it is right now. This is how it looks right now
So about the same amount that I am running in the rear. I wanted to keep my rig lower as well.
yes, the chassis dimensions are different & also the Wheel base is different.
Yes, so you have a bit more room to play with. Do you want to keep the lower links up on the side of the frame, as I did in order to keep your frame clearance as high as possible? If so it makes things a bit harder due to your wider frame. But still doable.
Wow.!!! This is great. A repository of valuable information. This will help me a lot. One thing I noticed is that you have used regular bushing at the axle end and jonny joints at frame end. Why? What if we have JJ at both ends? Any pro's cons?
I had a really good reason, JJs are expensive.
The main advantage of putting JJ on both sides is a bit more additional flex. We were going for ride quality first so I decided to just put the JJ on one end. We designed the system so we can always cut off the other end of the tube and put joints on if needed.
I will share the x/y/z dimensions for upper/lower link for both the frame & axle ends.
Thanks. I had read these 2 articles loooooong back and need to refresh my memory again. I have the calculator with me but would need help in interpreting the output numbers and various options.
BRD HNTR has probably spent more time looking over numbers then I have. He just finished building a 4-link on the back of his Tracker project.
