Technical Discussion - Beginner / Repair
88 sammy transmission bolt?
elf
102
~~~ZUKIUP~~~
September 29, 2010, 06:20:24 PM »
Lost the bolt on top of my transmission and now it leaks oil when at angles. The bolt is right behind the plug for reverse lights. Any one know what size bolt is so I can replace it?
Suzuzi:: Squeeze between the shit they cant crawl over
Skyhiranger
3734
122
I don't buy, what I can build
Re: 88 sammy transmission bolt?
September 30, 2010, 08:50:07 PM »
Are you talking about the hole that points towards the drivers side? If so, no bolt goes in there, it is a rubber plug. Just find something to stick in there and silicone it up, to seal it, and it should be fine.
elf
102
~~~ZUKIUP~~~
October 01, 2010, 09:06:32 AM »
Thanks for the info will fix tonight thanks again!!
