samurai smoking when shifts
  • 1071 Views
Offline ColtonP
  • 147
« on: September 27, 2010, 09:11:29 AM »
Sorry about this repost but want to know what it would cost to fix? Cud I just replace the rings if that's the problem or will I have to overhaul the engine valves wud b easy enough I think if that's the problem.   It smoke between shifts .
1987 Suzuki samurai BONE STOCK
(SOLD)1990 Samurai 1.6 8v swap, Arb front air locker, spool rear, RRO coil suspension, Chromoly front axles, 33x13.5-15 Swampers, ARB Bumpers, Slider, fender flares, 6.5:1 transfer case, True beadlocks, 1.5" wheel spacers,Roll cage. All in all a lil over 10k in parts uuuggghhhh!!!!!(SOLD)
(SOLD) 2000 Chevy tracker, 4 door, 4x4, auto trans, 2 inch lift,265/70r16 (SOLD)
(TOTALED)1995 tracker lsi, tintop, 3speed auto trans, 2 inch lift, 2 1/2 inch exhaust, 30x 9.5 bfg a/ts, custom front bumper.(TOTALED)
Re: samurai smoking when shifts
« Reply #1 on: September 27, 2010, 09:30:01 AM »
Sounds like you need to do a leakdown test on it and see exactly where it is leaking. It could be rings, or it could be valve related, i.e. worn valveguides/seals.
« Reply #2 on: September 27, 2010, 10:10:31 AM »
Nicotine patches, smoking causes cancer, so it would be a good idea to
get your Samurai to stop smoking as soon as you can, or better yet, take
away the cigarettes that way it can't smoke between shifts.  :laugh:
Sorry I just had to post that, it's highly likely that you need to replace the
rings and you should do the head at the same time, do a minor rebuild, replace
the bearings, hone the cylinders, use the old pistons and put it back together,
should run at least another 80-100K miles
