running different diff ratios
  • 10 Replies
  • 2804 Views
Offline ColtonP
  • 147
« on: September 25, 2010, 01:35:18 PM »
I'm interested in the consequences of running to different gear ratio cuz I'm to lazy to do my front diff.
1987 Suzuki samurai BONE STOCK
(SOLD)1990 Samurai 1.6 8v swap, Arb front air locker, spool rear, RRO coil suspension, Chromoly front axles, 33x13.5-15 Swampers, ARB Bumpers, Slider, fender flares, 6.5:1 transfer case, True beadlocks, 1.5" wheel spacers,Roll cage. All in all a lil over 10k in parts uuuggghhhh!!!!!(SOLD)
(SOLD) 2000 Chevy tracker, 4 door, 4x4, auto trans, 2 inch lift,265/70r16 (SOLD)
(TOTALED)1995 tracker lsi, tintop, 3speed auto trans, 2 inch lift, 2 1/2 inch exhaust, 30x 9.5 bfg a/ts, custom front bumper.(TOTALED)
Re: running different diff ratios
« Reply #1 on: September 25, 2010, 02:21:40 PM »
Broken axles, twisted drive shaft, scrubbing the tires to death, broken
T-case chain, Did I miss anything???
Offline my996duc1
  • 222
« Reply #2 on: September 25, 2010, 03:25:06 PM »
when you change the rear ring and pinion gears then just remove the front driveshaft....this when you are tempted to throw it in 4wd you won't do any/all of the above listed damage.... no problems then.
when you do the front ring and pinion gears then install the front driveshaft again.
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
« Reply #3 on: September 25, 2010, 03:31:58 PM »
T-case will leak all the oil out if you remove the drive shaft, you will have
to leave the slip yoke part in and suspend the front of the shaft to keep
the oil in
Offline ColtonP
  • 147
« Reply #4 on: September 25, 2010, 04:07:56 PM »
Wow none of those sound good guess I need to find a stock diff to fit in my kick.   Ne one gotta 4.30 or my rear straight un bolt then bolt
Offline my996duc1
  • 222
« Reply #5 on: September 25, 2010, 06:51:01 PM »
didn't realize we were talking about a 'kick....
that's one of my dislikes of this site, maybe it is just me but how the HECK do you tell what people are talking about, Sami or Kick ??????
« Reply #6 on: September 25, 2010, 07:25:28 PM »
I knew because I read the other posts, also a Samurai isn't hard to
change the diff, the Kick you got to drop the axle to swap the diff
Offline jaunty
  • 48
« Reply #7 on: September 26, 2010, 08:27:49 AM »
Ditto! I think a separate section is in order....
Offline doughboy0379
  • 290
  • 9
« Reply #8 on: September 26, 2010, 06:03:54 PM »
That, OR at the start of a post/thread we all say model maybe even the year since even Sami's have a few different things over the years like 88 yokes are different then 88.5 yokes and so on.
« Reply #9 on: September 27, 2010, 04:44:04 AM »
There are model specific sections, although they aren't well used at present.
Offline ldodge92
  • 107
« Reply #10 on: September 27, 2010, 05:56:54 AM »
I just replaced the front diff in my 91 kick. Im no expert mechanic and did it in about an hour. Found the new diff at a junk yard. Just need to find out what year has the gears you need. But i would suggest just finding one with the front and rear with 5.12. If your gonna do the work might as well change the gears.
My new addiction
