turning my headlights off perm.
  • 2256 Views
Offline Bfunk
  • 406
« on: September 21, 2010, 11:56:28 AM »
I just got a 98 tracker and am wondering if anyone what wire to cut to make the headlights not come on when I take the parking brake off?  I have 3 wires going to the bulb, 1 is constant, 1 is on off(highbeam made no differnce) and 1  had about 6 -7 volts all the time.  The lights work in all modes, but when I put me tester on the plug I just got more confused ???  Nayone witha wiring diagram would be a big help.  The only reason I want them off is so when I start wheeling this thing the pictures turn out good ;)
Brian
Re: turning my headlights off perm.
« Reply #1 on: September 21, 2010, 12:08:09 PM »
What you are looking to do is disable the daytime running lights.  You may have the same setup as my 96.  Check back and to the left of your clutch pedal.  Is there a small black box there?  If so remove the plug and see if that disables your daytime running lights and the low beams.  If that works then go ahead and remove the #7 pin, black with a white stripe next to the unused plug.  That is the line to turn on your daytime running lights.  Re-connect the plug after and your low beams should still work fine.
Do not just cut one of your headlight wires.  This will disable your low beams and you will have to run on high beams only which is illegal in most areas.
Offline djlantis57
  • 871
  • Take your chrome home
« Reply #2 on: September 22, 2010, 07:46:49 PM »
I know on my family's old 97 Chevy tahoe, the DRLs would come on whenever the parking brake was applied, no other way to shut them off...so the trick I learned is to apply the parking brake pedal just enough to hit that switch.  Usually only one or two clicks away from the full release position...it shuts the lights off, and isn't applied far enough at all to actually have dragging brakes.  The indicator light will show up, but if you can live with that, go for it.  I know on my 90 Tracker I can pull up on the parking brake lever one click and the "BRAKE" light will show up, but the brakes aren't actually applied, the microswitch is "fooling" the electrical system into thinking it is.
If that works for you, it's more temporary and doesn't require you to delve into any wiring.
Offline Bfunk
  • 406
« Reply #3 on: September 24, 2010, 10:52:05 AM »
I was looking for more of a proper fix.  I like knowing if there might be a brake issue before I push the pedel.  I'll look under the dash to today.
Brian
Offline Bfunk
  • 406
« Reply #4 on: October 05, 2010, 09:50:01 AM »
Ok I looked and can see no little black box.  I see nothing that would make any sense to disable the lights.  Any one have a wire diagram for a 98 tracker ???
Brian
« Reply #5 on: October 05, 2010, 12:37:44 PM »
Is yours a 98 Tracker or a 98 Tracker Sport?
Offline Bfunk
  • 406
« Reply #6 on: October 06, 2010, 12:45:44 PM »
chevy tracker
Brian
« Reply #7 on: October 06, 2010, 03:34:48 PM »
They are usually behind the dash to the right of the steering column or behind the dash to the left.  There is nothing on the firewall next to the clutch pedal huh?
I'll see if I can track down a diagram showing there the DRL module is on a 98.
