Trans Shifter
  • 1122 Views
Offline jow003
  • 403
Trans Shifter
« on: September 21, 2010, 07:33:02 AM »
Is there any secret way to get the transmission shift knob off?  i tried unscrewing it and it didnt budge.  is it glued or just screwed on there tight?
BUY MY STUFF!! pm for details
87 Samurai...
5" SPOA/OTT -RRO
1.5" leaf springs-OME
RUF conversion-Trail Tough
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Offline my996duc1
  • 222
Re: Trans Shifter
« Reply #1 on: September 21, 2010, 07:39:08 AM »
screwed on, regular threads (meaning turn counter clock-wise to take it off).
I was replacing my trans shift knob so I used a set of vice grips (with a strip of rubber underneath) to hold the stick and a set of adjustable pliers on the knob. This method will mess up the plastic knob so I wouldn't go this route unless you are replacing it.
I had thought about using one of the adjustable rubber strap wrenches (made for oil filters) but I was putting on a new one so it didn't matter how I got it removed or what condition the knob was in afterwards.
« Last Edit: September 21, 2010, 07:42:13 AM by my996duc1 »
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
Re: Trans Shifter
« Reply #2 on: September 21, 2010, 08:25:11 AM »
The knob is glued and screwed on there.  Some come off really hard.
Offline jow003
  • 403
Re: Trans Shifter
« Reply #3 on: September 22, 2010, 07:34:57 AM »
It amazes me how easy Vice Grips make a tough job!!  Tahnks guys, had it reinstalled in ~20 min
And it didnt chew up the knob much at all
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Offline fuzzy1
  • 350
Re: Trans Shifter
« Reply #4 on: September 22, 2010, 09:57:03 AM »
Too late now that you're done, but I always use strap wrenches to take em off. Lots of torque, no mars.
Non Illegitimi Conterat
