87 Samurai Front Differential Rehab
  • 939 Views
Offline garyvd
« on: September 19, 2010, 02:20:51 PM »
I recently bought an '87 Samurai hard top. It had quite a bit of front end noise in 4-w drive with the hubs engaged. I pulled the wheel assemblies and everything looked good and seemed smooth and quiet but the differential had quite a bit of end play and a little grinding when rotating by hand so I pulled it and got another clean, used one to replace it. Now I noticed that the front axles on both sides have maybe 1/8th to 3/16's inch of end play. Could that be where I was getting the rattle from and should I rebuild/replace the wheel knuckles too. The hubs seem good and they work smoothly.
Thanks a lot
garyvd
Re: 87 Samurai Front Differential Rehab
« Reply #1 on: September 19, 2010, 05:15:46 PM »
By "end play" are you meaning you can pull the axleshafts in and out?  If so, it is normal, don't worry about it.
Offline garyvd
« Reply #2 on: September 19, 2010, 05:58:14 PM »
Yes. Rotationally, it is quite tight in my rather uninformed opinion.
