Steeting Tie rod flip
  • 16 Replies
  • 3898 Views
Offline jagular7
  • 1026
  • Jagular7
Re: Steeting Tie rod flip
« Reply #15 on: June 22, 2004, 01:10:15 AM »
Forgot to add, with that addition, drill out original hole and bolt the addition to it also. This strengthens the 'reach' of the new arm, ties it into the knuckle, and the mount of the knuckle.
If anything, you could do a heim joint between the two for the steering.
Lenexa, KS
Offline Medford
  • 184
« Reply #16 on: August 26, 2010, 08:19:47 AM »
Mikerpm- Do you have pictures of what you did.  This topic is one I am dealing with currently, and I see there are several guys smarter than me that have already been there.
Whitfield- What did you end up doing, and did it work?
