95 engine to 97
  • 1641 Views
Offline ColtonP
  • 147
95 engine to 97
« on: September 16, 2010, 03:32:10 PM »
I can get a 97 four door pretty cheap but it needs an engine I have a 95 two door they are both 1.6 engines could I swap engines with no problem ???
1987 Suzuki samurai BONE STOCK
(SOLD)1990 Samurai 1.6 8v swap, Arb front air locker, spool rear, RRO coil suspension, Chromoly front axles, 33x13.5-15 Swampers, ARB Bumpers, Slider, fender flares, 6.5:1 transfer case, True beadlocks, 1.5" wheel spacers,Roll cage. All in all a lil over 10k in parts uuuggghhhh!!!!!(SOLD)
(SOLD) 2000 Chevy tracker, 4 door, 4x4, auto trans, 2 inch lift,265/70r16 (SOLD)
(TOTALED)1995 tracker lsi, tintop, 3speed auto trans, 2 inch lift, 2 1/2 inch exhaust, 30x 9.5 bfg a/ts, custom front bumper.(TOTALED)
Re: 95 engine to 97
« Reply #1 on: September 16, 2010, 08:22:13 PM »
If they are the same type of engine, like 8V or 16V, but you must swap the
intake or swap sensors so the computer gets the right info
Re: 95 engine to 97
« Reply #2 on: September 16, 2010, 08:36:10 PM »
Going from a 95 to 96 you will also need to swap the oil pump and oil pan to support the crank position sensor.  And the distributor, but not the distributor housing.  That is the same.
You might also have to swap the heater/water tube that sits between the block and the alternator.
