lock rite locker and stock side gears?
  • 1426 Views
Offline zeabutizillie
  • 9
  • 1994 tracker lsi 3 3 calmini , 31's, cal stabalize
« on: September 15, 2010, 07:34:32 PM »
Has anyone used a lock rite locker without the coupler in a track kick?
Re: lock rite locker and stock side gears?
« Reply #1 on: September 15, 2010, 07:42:18 PM »
Ya, all the lockers I've installed have used side gears instead of
couplers, if you don't have broken sidegears, use them
Offline rascott
  • 669
  • 15
« Reply #2 on: September 15, 2010, 08:00:38 PM »
i did this about 3 years ago.
the diff. had 150000 miles on it(i believe) but the gears looked fine.
i reused the dowels, as the ones in the kit were not drilled for the pins.
i have had no problems.
lockrite recommended 140w gear oil, so i followed their advise.
replaced the outer axle seals also- kinda pia, but you're in there- might consider.
  • 9
« Reply #3 on: September 16, 2010, 03:26:22 PM »
thanks so much guys that makes me happy.hard to rip apart a working wheeler when it rains everyday when unsure if i needed the coupler. yaaahooo oops that was on the inside
