Transmission replaceing
  • 2149 Views
Offline ColtonP
  • 147
« on: September 08, 2010, 04:14:09 AM »
I'm going to a junkyard this saturday I need to know what transmission are a direct match to my vehicle with no modifications of any kind just pull mine put new in and drive 1995 geo tracker 1.6 16v my concern is they sell sidekick and chevy parts idk what would be interchangeable please help.  THANK YOU
1987 Suzuki samurai BONE STOCK
(SOLD)1990 Samurai 1.6 8v swap, Arb front air locker, spool rear, RRO coil suspension, Chromoly front axles, 33x13.5-15 Swampers, ARB Bumpers, Slider, fender flares, 6.5:1 transfer case, True beadlocks, 1.5" wheel spacers,Roll cage. All in all a lil over 10k in parts uuuggghhhh!!!!!(SOLD)
(SOLD) 2000 Chevy tracker, 4 door, 4x4, auto trans, 2 inch lift,265/70r16 (SOLD)
(TOTALED)1995 tracker lsi, tintop, 3speed auto trans, 2 inch lift, 2 1/2 inch exhaust, 30x 9.5 bfg a/ts, custom front bumper.(TOTALED)
Re: Transmission replaceing
« Reply #1 on: September 08, 2010, 08:26:05 AM »
Auto or manual? Auto is more critical, as that year is a computer controlled
auto trans, but if you have a manual, it really makes no difference, they all
will work, but there could be some minor gearing changes if swapping say
an 8V trans instead of a 16V trans, I'm not sure if there were gear ratio changes
between the different years on the manual trannys
Offline ColtonP
  • 147
« Reply #2 on: September 08, 2010, 08:36:41 AM »
3spd auto sorry about that
« Reply #3 on: September 08, 2010, 10:02:19 AM »
Really, 3 speed, I didn't think they used 3 speed transmissions in
95. It is a 3 speed it's made by GM TH180, if it's made by Aisin
which is a division of Toyota, it is a 3 speed w overdrive or called
a 4 speed on this forum.
I'm not aware of any different types of transmissions other than these two
but it is critical that you get the same one or you could have problems with
it working correctly
Offline ColtonP
  • 147
« Reply #4 on: September 08, 2010, 01:36:37 PM »
Just three speeds lol 1 2 3
« Reply #5 on: September 10, 2010, 06:37:36 AM »
The 3 speed autos were available in the 2 door trackicks until at least 98.
Yes, a 3 speed needs to be replaced with a 3 speed, because a 4 speed is computer controlled and will not function properly without a major wiring and ECM change.
« Reply #6 on: September 10, 2010, 08:46:17 AM »
Thanks for the Trans update Skyhi, I didn't knew they used those for that long
« Reply #7 on: September 10, 2010, 02:25:21 PM »
Has anyone done the Vovlo 4speed swap?  I know there was talk there for a while of it being the same transmission as the 4 speed Sidekick auto only with a manual shift kit instead of electronic.
