hitch
  • 12 Replies
  • 1625 Views
Offline Toy Box
  • 222
  • 00 Grand Vitara
hitch
« on: September 07, 2010, 08:56:44 PM »
Can you guys show your  tow hitch in a picture and brand. looking to buy one. I have a GV 2000
« Last Edit: September 07, 2010, 08:58:19 PM by Toy Box »
You Play you Pay
Offline 3stagevtec
  • 204
  • killing two stones with one bird...
Re: hitch
« Reply #1 on: September 08, 2010, 01:26:43 AM »
IIRC, there are already nuts welded in place on the chassis at the rear.. take a look from underneath.
A DIY hitch using those should be pretty easy.
Offline 3stagevtec
  • 204
Re: hitch
« Reply #2 on: September 08, 2010, 01:30:59 AM »
  • 4312
  • 167
Re: hitch
« Reply #3 on: September 08, 2010, 06:10:07 AM »
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
Offline Teniente
  • 50
Re: hitch
« Reply #4 on: September 08, 2010, 06:18:40 AM »
It's five o'clock somewhere!!
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: hitch
« Reply #5 on: September 08, 2010, 08:51:55 AM »
Getting one of the Curt class III right now.  Actually should arrive today.
I have a no-name (was painted over) Class I hitch if anyone's looking.  Selling it cheap, comes with a tongue and 1 7/8" ball.  Dirty and surface rust but solid.  Lemme know if anyone is interested.
Offline bush buster
  • 263
Re: hitch
« Reply #6 on: September 08, 2010, 09:01:55 AM »
I went with the Reese.  It installed easily with 4 bolts, although the nuts that are already welded in the frame were so rsuted I had to re-tap them. Fits nice and tight to the bumper/gas tank area.
(FOR SALE, drop me a line) '01 Vitara 2.0, 2" suspension lift, 2" body lift, 31x10.5x15 Interco TRXUS MT's on ford truck turbine rims, 1" wheel spacers, manual hubs, 5125 gears (Sidekick rear and GV steel front). DD/bushmobile "Snowflake"
'06 Impreza - Wife's ride and road tripper
1975 Dodge 360 Sportsman 1 ton van chassis with a 21' Triple E Class C motorhome
Offline Teniente
  • 50
Re: hitch
« Reply #7 on: September 09, 2010, 04:47:37 PM »
Did the install of my Curt Class III (JC Whitney) today. Took about 30 minutes working by myself. Hitch lined up with the threaded bolt holes with no problems.
The Wiring "T" connector, also from JC Whitney:
http://www.jcwhitney.com/t-connector-kits/p2018063.jcwx?filterid=d336y2000j1&_requestid=12075790
........took less than 5 minutes.........the connector is in the jack storage door.....plain sight.......just plugged in!!!!!
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: hitch
« Reply #8 on: September 09, 2010, 06:46:22 PM »
I actually installed my Curt Class III hitch today as well.
Was slightly disappointed to find the holes didn't line up.  I did however figure out it was because one of the mounting flanges was curved inwards slightly.  A bit of back strain and some 2x4's later I had it close enough I was able to muscle it on.  Dunno if it was a manufacturing defect or just it had something heavy sitting on it in the warehouse, who knows.  No visible marks or creases so I figure whatever happened happened slowly and not an impact.
Little surprised it came with 8.8 bolts and not 10.9 bolts but I can fix that later on.  I just need a hitch this weekend.
Offline Crazy4x4
  • 42
Re: hitch
« Reply #9 on: September 11, 2010, 12:02:43 PM »
On my old one I installed a U Haul hitch. I wanted a 2in but this is all they had on hand and I didn't feel like waiting. It included the bolts to install. Just like said above the nuts are welded on the frame.  Very easy took 10min or less.
Finally a 4low on a small SUV with GREAT MPG!!!!
2001 Grand Vitara 4x4 2.5LV6 Auto
1993 Dakota 4x4 5.9 V8 33in rear locker 10,000Lb winch TONS more!
Offline Toy Box
  • 222
  • 00 Grand Vitara
Re: hitch
« Reply #10 on: September 12, 2010, 07:58:15 AM »
Thanks they all look like nice and close to body, gas tank,
You Play you Pay
Re: hitch
« Reply #11 on: September 13, 2010, 08:49:56 AM »
I put on a Uhaul class 3.  About $120.  Install easy.  remove tie down hook from frame, attach with 4 bolts into existing threaded holes, torque to specs, and voila!  Pulls the full 1200 max tow (per manual), and can handle a platform cargo carrier.  The class 1 will advise to not use for a receiver bike rack or a platform, but only for towing small toys like a jet ski.
rogue valley blue
2001 GV auto with K&n air, BFG AT KO's (215/70/16), magnaflow secondary cat and muffler with 2.25 inch pipe, now using Mobil One in the crankcase.
Offline skahre
  • 22
Re: hitch
« Reply #12 on: September 22, 2010, 10:29:26 AM »
I put one of the CURT class III 2" receivers on my 2002 Tracker.  I had the same experience as AJMBLAZER that the holes didn't line up quite right.  It took some serious leverage and many choice words, but eventually I got the bolts started.  That was two years ago, and it's held up very well since.  I'm especially impressed with the powder coat finish.  Aside from the tube where the stinger goes, there's no rust yet.  Heck, the CURT sticker is still on it.  Sorry, no pics here at work . . .
'02 Tracker 4dr 4X4
2.0L, 5-Speed
Stock except:
215-75R15 AT tires
Drilled-out airbox w/ K&N
