Tracker still shutting down
  • 18 Replies
  • 2853 Views
Re: Tracker still shutting down
« Reply #15 on: September 10, 2010, 06:46:39 AM »
The computer seems to be ok
What is that?  That is not an ECM for a trackick.  A trackick ECM has a gray painted metal case and has 2 wiring plugs that plug into it.  That looks nothing like that.
« Reply #16 on: September 10, 2010, 06:48:36 AM »
Can you tell me where the fuel pump relay is located ?
On a bracket on the underside of the ECM (the ECM is on a bracket located in behind the drivers side front stereo speaker).  The fuel pump relay will have a connector that has at least one pink wire running to it.  The other identical relay that is next to the fuel pump relay is the main relay.
« Reply #17 on: September 10, 2010, 08:44:24 AM »
They must of moved them in the later trucks, I would swear mine was under the hood,
I jumpered the relay plug to run the fuel pump with the engine off to do some fuel PSI
testing when I was building the turbo setup, that was like 8 years ago, so you see why
I wasn't sure which one it was
« Reply #18 on: September 10, 2010, 12:41:08 PM »
Nope, they are all right by/under the ECM.
