Tracker still shutting down
  • 18 Replies
  • 2846 Views
Offline blaster716
  • 53
« on: September 04, 2010, 04:52:28 PM »
My tracker starts up and purrs like a kitten , after 5 or 10 min. or so it just shuts down as if I shut the key off and will not restart untill it sits for about 5 min.
I replaced the ignition module , no change so I replaced the coil and still no change , any idea where i go from here ?
Re: Tracker still shutting down
« Reply #1 on: September 04, 2010, 08:16:40 PM »
What year is the truck?
I'm thinking the computer and the bad capacitor problems some early
models had
Offline blaster716
  • 53
« Reply #2 on: September 05, 2010, 05:35:38 AM »
It`s a 93
« Reply #3 on: September 05, 2010, 08:22:46 AM »
I'm not sure about that year, Is it a 16V or 8V engine?
Offline blaster716
  • 53
« Reply #4 on: September 05, 2010, 04:18:01 PM »
8v motor , automatic trans.
« Reply #5 on: September 05, 2010, 05:18:53 PM »
OK, the only way I know that you can figure out if the computer has
the bad, leaking capacitors is to remove the computer from under the
dash, it's on the drivers side, and look at the board, if there is corrosion
and swelled capacitors (tops will look like a dome instead of flat) then
you need to replace the caps, or send it in for repair if you are not able
to do the work yourself
Offline blaster716
  • 53
« Reply #6 on: September 06, 2010, 07:35:10 PM »
Where should i send it to be repaired ? and any idea how much it will cost ?
« Reply #7 on: September 06, 2010, 10:17:07 PM »
Did you pull the computer out and verify it needs repair?
it may not need anything and we will start looking at other
problems that it could be
Offline blaster716
  • 53
« Reply #8 on: September 07, 2010, 03:26:30 AM »
Ill pull it out after work
Offline blaster716
  • 53
« Reply #9 on: September 07, 2010, 04:16:59 PM »
The computer seems to be ok
« Reply #10 on: September 07, 2010, 06:24:54 PM »
That looks like the old style caps have been replaced with new
surface mount ones, look on the back side for brown spots where
the board has got hot, this could also indicate the problem spot
if there is one
Offline blaster716
  • 53
« Reply #11 on: September 08, 2010, 02:50:20 PM »
I see no problem here , everything looks like new , any idea what to look at next ?
« Reply #12 on: September 08, 2010, 07:29:55 PM »
After the truck runs and stalls, and then will not start, have you checked to
see if the ignition is still sparking? If it is, then you might have a bad fuel pump
or a bad relay that is shutting off the pump
Offline blaster716
  • 53
« Reply #13 on: September 09, 2010, 06:15:15 PM »
Can you tell me where the fuel pump relay is located ?
« Reply #14 on: September 09, 2010, 09:40:36 PM »
Under the hood next to the battery I think.
It's been a while since I messed with it
