need help with Hagen widen mod
  • 23 Replies
  • 4676 Views
Re: need help with Hagen widen mod
« Reply #15 on: March 20, 2012, 09:10:32 PM »
I ended up using a sawzall, and another A arm.  Soak and wait, beat & bash, then replace what is left.  I do not have hardly any rust on my Tracker, but the bolt on one side was stuck solid.
Offline MongooseVRX
  • 64
    • M.O.S. forum
« Reply #16 on: March 23, 2012, 04:17:41 AM »
Well, my tracker is called "the rusty Mongoose", so after reading your post I decided to bust out the cut-off wheel and cut the bolts out. Ordered new bushings($20.00 each). Thanks for the info BRD HNTR!
1993 2-Door Tracker 1.6l 8v 5-speed manual hubs
Minnesota Overland
Offline talonxracer
  • 1284
« Reply #17 on: March 23, 2012, 06:43:08 AM »
I cannot get the a-arm bolts(the ones that will move outward) out to move them >:( I started soaking them with penetrating oil a few days ago. I can turn them with a socket and a breaker bar, but they will not come out. I've been pounding on them with a brass bar and hammer, but no luck. I'm afraid to use heat as to not damage the rubber bushings. How did you guys get thoes bolts out?
The bolts have siezed within the center bushing due to corrosion. This is to be expected anywheres but the southwest, LOL
I usually torch the arms out and replace the bushings at that point. I have never seen any penetrating oil like PB-Blaster succedd in breaking the galvanic corrosion down. When any moisture gets between the bolt and center bushing, the plain steel bushing and galvanic coated bolt create a electrical charge and the galvanized coating actually bonds to both surfaces(just like applying chrome coating) basically welding the parts together.
Anti-sieze is your best friend during reinstall!!!!!!!!!!!!!!!
« Reply #18 on: March 23, 2012, 07:13:24 AM »
Changing the bushings isn't fun w/o a press, but it can be done.  Remember that you tighten the A-arms after it is setting on its wheels under weight.  Otherwise the rubber in bushing is always setting under tension.
Offline talonxracer
  • 1284
« Reply #19 on: March 23, 2012, 07:38:37 AM »
I have done poly inserts without a press to remove the old bushings, drill/torch the rubber enough to remove the center bushing and use a hack saw to cut the outer bushing shell, not an easy job at all, and installing new factory bushings without a press is even harder.
Offline MongooseVRX
  • 64
    • M.O.S. forum
« Reply #20 on: March 23, 2012, 08:48:53 AM »
Anti-sieze is right up there next to beer on my must-have list in the garage! [%]D
Minnesota Overland
« Reply #21 on: March 24, 2012, 05:07:23 AM »
x3 ;D
Offline kreator
  • 634
  • 15
« Reply #22 on: March 24, 2012, 10:16:03 AM »
I dont drink beer but a shot of whiskey works !!! and dont be shy with the never seize give it the the idea that a little is good a lot is better and dont wipe your hands on your pants with the never seize on them your wife will kill you after she washes them in her machine and its all over it  and all over your cloths . >:D
« Reply #23 on: March 25, 2012, 06:24:19 AM »
:laugh: Been there!
