Rattle in 5th gear.
  • 1597 Views
Offline 87Sav
  • 6
Rattle in 5th gear.
« on: August 24, 2010, 07:12:22 AM »
I haven't driven my Sammy for long, but every time I go around 45-50 in 5th gear (usually right when I go to 5th gear)  it starts making a rattling noise. My dad says it sounds like the transmission. To explain the noise it's like a... Knocking/Rattling sound. It ONLY happens in 5th gear. Any suggestions?
Re: Rattle in 5th gear.
« Reply #1 on: August 24, 2010, 08:07:31 AM »
Check your trans oil, and it could be trans bearings, it's common
for a Samurai, not sure why tho
Offline jaunty
  • 48
« Reply #2 on: August 27, 2010, 10:28:12 AM »
put the t-cast in NEUTRAL so you can shift through the gears and rev to get a better listen to the gears and sounds its making..
