quick winch question
  • 1978 Views
Offline cmatt1605
  • 51
« on: August 24, 2010, 06:58:57 AM »
ok so around Sc we really only have trails with some small hills and LOTS of mud. so i was wanting a winch JUST in case, but my samurai does not get stuck on our trails very often. i was looking at the 3000 lb superwinch and just using a snatch block every time. i already have the ARB 66' winch extension so length isn't an issue. and there are ALWAYS trees around to winch to. basically my question is will the 3000lb winch with a snatch block be enough to get the samurai out of the mud?
Re: quick winch question
« Reply #1 on: August 24, 2010, 07:02:56 AM »
I tried a smaller winch when I first got into Zuk's and hated it.... The mud can/will act like a suction cup causing a need for much more pull than the weight of your vehicle... Many people here have purchased the inexpensive 8000# winches from Harbor Freight and have been happy with them. Since my first small winch I have always ran 8000# winches and they have never let me down.
HTH,
Offline cmatt1605
  • 51
« Reply #2 on: August 24, 2010, 07:04:08 AM »
ok thanks! does the 8000lb run around 200$?? i dont really want to spend more than necessary sense i will not be using this very often.
Offline my996duc1
  • 222
« Reply #3 on: August 24, 2010, 09:30:16 AM »
like most things... you are going to get what you pay for, and the juggle is not over paying for what you need.
Maybe cruise Craigslist for a used winch and get a bigger better brand of winch for less money than you can get one new.
I think you are better off buying a hand operated come-along than an under powered or cheap winch.
When you need the winch you are going to really want it to work flawlessly.
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
Offline lv2fsh
  • 312
  • 19
« Reply #4 on: August 24, 2010, 11:25:28 AM »
I got a 6000# Vortex winch off ebay. Their 5000# and 6000# are the same just $5.00 or so cheaper. The weight duifference between a 6000# winch and a 8000# winch about double. I personally don't want to carry all that weight around. I also got the one with the wireless remote. Just a 5000# which is really the same as a 6000# is $185.00 + shipping
Offline cmatt1605
  • 51
« Reply #5 on: August 24, 2010, 04:11:15 PM »
ok sounds good, i think ill go with the ebay one. thats the same price as a 3000lb and a snatch block
Offline lv2fsh
  • 312
  • 19
« Reply #6 on: August 24, 2010, 05:09:53 PM »
Get the 5000# one, it's the same exact one as rhe 6000#. When it came it was labled 6000#. I've used it twice and it worked good. I love the wireless remote (not all come with it).
Offline cmatt1605
  • 51
« Reply #7 on: August 24, 2010, 05:22:21 PM »
ok sounds good. im still waiting on my winch bumper from lowrange tho
