rebuild or replace engine
  • 1455 Views
« on: August 23, 2010, 04:10:49 PM »
I have one cylinder that is 30 psi rest are 120.  I pured oil in the cylinder and rechecked and it jumped up >100. So I guess I am looking at rings/piston-who knows.  Speedo says 75,000, but i could be 275,000 for all I know.
Is it worth it to try to rebuild these sammy motors (??? bucks) vs replace (???).  Where can I even find a used engine?
This is depressing, I was looking forward to fixing my new toy-
thanks for the help.
Re: rebuild or replace engine
« Reply #1 on: August 23, 2010, 06:51:36 PM »
Get a set of rings, some rod and main bearings and have the valves
either ground or replaced depending on their condition, then put in
a new water and oil pump and a new timing belt, you need a gasket
set and hone the cylinders, this will reuse the old pistons and go another
trip around the planet before you need another engine.
This is like $300 in parts and a whole lot of satisfaction that you brought the
engine back to life
« Reply #2 on: August 25, 2010, 05:31:35 PM »
where is the best place to order the parts needed to rebuild?
Thanks a ton
« Reply #3 on: August 26, 2010, 03:26:57 PM »
Low Range Off Road has great service.  Sammy Pro is another good source when dealing with engine related items.
« Reply #4 on: August 26, 2010, 04:03:21 PM »
I bet you can find a good 1.6 8 valve to drop in it for about the same $ and less work and get more power to boot . But then of course, you won't have the satisfaction of building your own engine, several times if you've never done it before! >:D
