4spd automatic interchangeability
  • 2137 Views
Offline dustybadlands
  • 169
    • dustybadlands treeslammer
« on: August 23, 2010, 01:17:13 AM »
I have to choose between a 1st gen 4 spd or a 2nd gen for use in a '97 4 door I'm building up and I'm trying to determine which to use. Are there ECU issues with the lock-up torque converter or anything else? Also, are there differences in the transfer cases? I will be running 31X10.50's so that means I'm keeping the 5.12:1 diffs. Just lookin' for the best combo.
"If nuthin' changes, nuthin changes. Do what ya  always did, get what ya  always got !"
  • 169
Re: 4spd automatic interchangeability
« Reply #1 on: August 25, 2010, 10:34:45 PM »
Anybody wanna guess?  ???
« Reply #2 on: August 25, 2010, 11:28:33 PM »
What are you calling 2nd gen?
I thought all the 4 speeds were made by Asian?
  • 169
« Reply #3 on: September 22, 2010, 02:16:35 AM »
Whoa! How time flies - Okay, I'm back. To me, 2nd Gen means 99+. What I was wondering was if the plugs are different or the lock up torque converter sequencing or anything of that nature.
« Reply #4 on: September 22, 2010, 08:14:22 AM »
You might ask about parts interchangeability at a pull it yourself auto
dismantle yard, some here will tell you what other cars or years also
have your same part. Also an internet search might list compatable
transmissions and the years they fit
« Reply #5 on: September 29, 2010, 03:38:27 AM »
SIDEKICK 4 DOOR      92-98      4 SP 2 & 4WD      L4 1.6L      03-72LE
GRAND VITARA/VITARA     99-06     4 SP RWD/AWD     L4 1.8L/2.0L V6 2.5L/2.7L     03-72LE
XL-7     01-03     4 SP FWD/AWD     V6 2.7L     03-72LE
Here's the full list of Suzuki transmissions used/when.
http://www.transtec.com/selector_guide/Suzuki.htm
IIRC The trans and T-cases are the same down to the output shaft spline count.
`00 2D 2.0L Auto Tracker, Jeff1997's 2" Coil Lift, Mudchild's 2" Body Lift and 31x10.5R15 General Grabber Competition Tires
