Almost ready to tow but nervous
  • 2387 Views
« on: August 22, 2010, 01:10:42 PM »
OK I have had my sammy 2 years now but have only wheeled locally but I am ready to venture out to some further locations. I got my receiver hitch and tow bar set up and it is my understanding I put the transfer case in neutral and  put the trans in 2nd gear but post like this make me nervous what and the odds of something like this?
http://www.airforums.com/forums/f160/my-suzuki-samurai-dropped-into-gear-while-being-towed-4186.html
« Last Edit: August 22, 2010, 01:14:50 PM by zuktinter »
Offline MadMaxZuki
  • 77
Re: Almost ready to tow but nervous
« Reply #1 on: August 22, 2010, 05:15:29 PM »
remove your rear driveshaft when towing. then you will have nothing to worry about, the drivetrain will be isolated. and make sure your hubs are unlocked. the 15 minutes of work is worth the piece of mind.
88.5 Samurai 33" TSL, 6.5:1 Xcase Gears, 92" wheelbase, 3link rear, SPOA front w/ drop shackle, open/locked. Soon to be this spring: Toyota front and Dana44 rear w/ homemade offset.
Offline 96Kicker
  • 1043
  • http://www.zukiworld.com/forum/gallery/3710_25_10_
    • www.myspace.com
« Reply #2 on: August 22, 2010, 08:02:08 PM »
I flat towed my 87 samurai with the t case in neutral and tranny in third gear 900 miles with no issues what so ever. Every time I stoped for fuel I started the samurai for a little bi cause the key was on.
<a href="http://s220.photobucket.com/albums/dd126/fletcher9160/?action=view&current=Zuktahgreenblur.jpg" target="_blank"><img src="http://i220.photobucket.com/albums/dd126/fletcher9160/Zuktahgreenblur.jpg" border="0" alt="Zuktah club sticker"></a>TJ
#801-554-3281
96 kick 4 door with custom 3 inch susp lift and pre runner front bumper,2 inch bod
Offline my996duc1
  • 222
« Reply #3 on: August 22, 2010, 08:43:27 PM »
follow the instructions :
http://www.petroworks.com/pdf/How%20to%20Flat%20Tow%20a%20Samurai.pdf
triple check everything and you should be fine.
these things have been towed thousands miles with zero issues.
If you do mess it up then it can be costly.... like alot of things in life.
If you are worried about it then rent a Uhaul trailer and be done.
Another option if you are going to tow alot is a driveshaft disconnect :
http://www.trailtough.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=89&category_id=12&option=com_virtuemart&Itemid=53
« Last Edit: August 22, 2010, 08:46:22 PM by my996duc1 »
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
« Reply #4 on: August 22, 2010, 09:37:18 PM »
You can unscrew the shift knobs and take them off to make it harder for the gears to in gage and I would put the trans in fifth, this happend to a friends rig on a long trip and he got lucky with it just pumping oil up on the top end of the engine and lots of smoke for a while but his engine was screaming for several hours behind a 7.3 turbo diesel.
Offline Jluck
  • 1389
  • 40
« Reply #5 on: August 23, 2010, 06:23:08 AM »
Am I missing something here??? Why can't you just put the transfer case in neutral? ???
Offline my996duc1
  • 222
« Reply #6 on: August 23, 2010, 07:40:02 AM »
You are supposed to put the t-case in neutral but it is not a true neutral....
read the entire page about why on this link :
Offline Jluck
  • 1389
  • 40
« Reply #7 on: August 23, 2010, 07:49:20 AM »
gotcha. thanks. learned something new. :o
« Reply #8 on: August 27, 2010, 07:21:16 AM »
Thanks for all the great info guys.
