snorkel, header, and 2 1/2 exhaust
  • 19 Replies
  • 4289 Views
Offline smife
  • 179
« on: August 22, 2010, 07:26:27 AM »
I installed a snorkel 2 1/4 exhaust pipe. Then installed a Thorley header with no cat and generic flowmaster with 2 1/2 pipe all the way back. It seems like I lost power. Do I need to have a muffler on it to create some backpressure to get my power back? Oh yeah 1.6 16v
« Last Edit: August 22, 2010, 08:01:00 AM by smife »
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
Re: snorkel, header, and 2 1/2 exhaust
« Reply #1 on: August 22, 2010, 07:39:56 AM »
Should put the size motor         but yes the lack of back press can rob power
« Reply #2 on: August 22, 2010, 08:36:49 AM »
2 inch for these engines, but you could try putting on a 1-3/4 or 2"
after your muffler and see if it creates a torque tube affect that they
are doing on the new trucks, the only problem might be I think they
are tuned lengths for the displacement of the engines.
This works like an expansion chamber on a 2 stroke motorcycle
« Reply #3 on: August 23, 2010, 04:40:20 AM »
How is your snorkle filtered? through the airbox, or did you just put a filter on the end?
Offline smife
  • 179
« Reply #4 on: August 23, 2010, 05:07:02 AM »
Yes its filtered throught the airbox with a K&N Filter.
Offline jow003
  • 403
« Reply #5 on: August 26, 2010, 06:06:57 AM »
got any pics of how you did the snorkel? is it a kit or did you make it?
BUY MY STUFF!! pm for details
87 Samurai...
5" SPOA/OTT -RRO
1.5" leaf springs-OME
RUF conversion-Trail Tough
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Offline grats
  • 28
« Reply #6 on: August 26, 2010, 09:23:37 AM »
Here's one I made for my samy that's filtered through the original air box.
1982 SJ410
1997 Tracker
2008 SX4
« Reply #7 on: August 26, 2010, 04:09:54 PM »
Granted, My engine is turbocharged, but I also run a snorkle, through the airbox with a K+N filter, the downpipe from the turbo is 2.5 ", NO cat, and 2.5 " tubing through a turbo style muffler and out through a 2.5" tailpipe. Mine is no stump puller down low, but it sure didn't lose any power when I built the 2.5" system. Maybe 2.5" IS too big for a stock engine, your just not moving enough air to utilize that big of diameter. IMO, I'd probably go back to a 2" system all the way on a stock engine.
Offline smife
  • 179
« Reply #8 on: August 26, 2010, 04:41:07 PM »
Yeah I'm going back to 2". 2 1/2" is just too much for a stock engine.
« Reply #9 on: August 26, 2010, 06:26:54 PM »
The turbo provides all the back pressure you need, so the better the exit
exhaust flow is the more potential for power.
Offline smife
  • 179
« Reply #10 on: August 27, 2010, 07:31:34 PM »
So maybe I should keep the exhaust and get a turbo!!! hahahah  I think that may be a little over my head right now.  All the broken and seized bolts are keeping me busy enough with my Calmini 3" install and widening mod. Unless someone has a complete turbo set up they would want to get rid of ???
Offline KJMac
  • 280
« Reply #11 on: August 31, 2010, 12:47:01 PM »
Smife,
I put a header on my 16v kick and it seemed to lose torque in a big way. I'm running 2.5" pipe with cat and homemade muffler. Straight through. I'm thinking about getting rid of the header!
Kj
« Reply #12 on: August 31, 2010, 07:21:50 PM »
It's not the header, it's too big of pipe.
« Reply #13 on: August 31, 2010, 08:25:10 PM »
Yep, you need a 2" pipe instead, don't take any lessons
from Rice Rockets, those are patterned after racecars
with turbo setups
Offline KJMac
  • 280
« Reply #14 on: September 03, 2010, 11:03:24 AM »
Bentparts,
You think a 2" tailpipe would help? May try that first!
Thanks,
Kj
