Does changing t-case gears help increase max speed?
  • 13 Replies
  • 3143 Views
« on: August 18, 2010, 11:01:12 PM »
Hey yall! I know you're tired of me asking about speed with the Sammy, but I have one more question. I have near stock 28" tires with stock gearing (T-case and dif's), and according to a gearing calculator I used at www.lepayne.com/gears.html, I lose 7% percent of my power because I'm 2 inches over the stock tires. I can currently reach a max speed of 65 and I was wondering if changing my t-case gears to 4.1 would help me reach a higher max speed? Or would it even decrease my max speed? I guess there is the other option though, that I can just be satisfied that I have one of the best off-roading vehicles and accept the fact that I will never reach out-of-town freeway speeds of 75 mph like a wimpy car! Thanks again!
Re: Does changing t-case gears help increase max speed?
« Reply #1 on: August 18, 2010, 11:09:29 PM »
Run that calculator again and plug in the reduction in high range
you get with the 4:1's. I think you are going to find the ratio will
be closer to stock or even lower, however, even with lower gears
the bigger tires sap more power that stock ones, so even corrected
the power will not be as good as stock, but it should help
« Reply #2 on: August 18, 2010, 11:21:00 PM »
OK, I pulled a number for you, a set of 4.16:1 t-case gears have
a high range reduction of 12%, that should help you figure out
the RPM and compare with stock tire/gear speeds
Offline jow003
  • 403
« Reply #3 on: August 19, 2010, 06:03:21 AM »
what about 33s with 6.5:1s >:D ???
BUY MY STUFF!! pm for details
87 Samurai...
5" SPOA/OTT -RRO
1.5" leaf springs-OME
RUF conversion-Trail Tough
1" shackles
33x1250x15 MTZs
15x8- DC-2s
« Reply #4 on: August 19, 2010, 08:09:30 AM »
Those have a high range reduction of 17%
« Reply #5 on: August 19, 2010, 09:36:26 AM »
So changing the t-case gearing basically just restores the power you once had after changing your wheel size eh? Good to know. Just for kickers, what would installing a 1.6L FI tracker engine or VW 1.6L TD do to your speed? I know it gives you more power, but would it increase your max speed with stock gearing?
Offline lv2fsh
  • 312
  • 19
« Reply #6 on: August 19, 2010, 10:07:23 AM »
With stock gears and 235's (29" or so) I could still hit 70-75 on flat ground. It just took a little longer. No prob on Socal freeways. You have to have the power in you engine. I would start on the engine because you could change gears all day and not be happy.
« Reply #7 on: August 19, 2010, 09:25:26 PM »
A 1.6 EFI engine is basically a stroker 1.3, with about 30%
more power, hard to increase a stock engine that much
Offline Zuki-Girl
  • 128
« Reply #8 on: September 18, 2010, 10:44:51 AM »
So if I pulled the very tired 1.3 out of my Sammi and replaced it with a 1.6 8valve and stock gears the effect of ,y 235's would be less of a strain? The 1.3 already has the 1.6 8 valve TBI on it.
« Reply #9 on: September 18, 2010, 01:43:17 PM »
I thought 235 tires were a really good match for a stock drive-train, and
on my truck it corrected the speedo to read 100% accurate, where before
it read 2-3 MPH faster than true ground speed
« Reply #10 on: September 19, 2010, 10:46:58 AM »
The 1.6 will pull 235s all day  :)
Offline Zuki-Girl
  • 128
« Reply #11 on: September 19, 2010, 02:02:29 PM »
Ok solves that problem then. Thanks!
Offline my996duc1
  • 222
« Reply #12 on: September 19, 2010, 08:44:15 PM »
I thought the :
6.5's are 20% reduction in high range
6.4's are 17% reduction in high range
Here is a good websites to punch your gearing/tire/t-case options to see what rpm at what speeds you will be pulling and also give you your crawl ratio in each gear.
http://www.grimmjeeper.com/gears.html
I am running a '87 1.6 16v with a 6.4 t-case, 4.30 r&p, and 31" tires... this has me running 4100rpm at 65mph and a crawl ratio of 100:1 (stock crawl ratio is about 31:1). I plan on going up to 33" tires and that should drop me under 4k rpm at 65 mph.
This combo has kept me able to run the Socal freeway (in the slow lane) and still crawl nice and slow.
« Last Edit: September 19, 2010, 08:52:44 PM by my996duc1 »
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
Offline joesteak
  • 74
« Reply #13 on: September 24, 2010, 04:23:49 AM »
Gearing multipies torque at the wheels, it doesnt do anything for power.  Since your final drive ratio at the wheels is the product of your tranny, transfer case and diff gear ratio, downshifting your tranny on the freeway would do the same as lower gears in your t-case.  If your car doesn't have the nut to maintain freeway speed, you need an engine with more horsepower.  So I'll second what everyone else is saying - you need a 1.6!
