tHERMOSTAT of Air Conditioning sys.
  • 994 Views
Offline rbeny
« on: August 18, 2010, 01:21:28 PM »
Car: Sidekick 97.
Problem: Gas compressor dos'nt stop.
Susspichious : Thermostat of Air Cond. sys.
Where is it locatet? how difficult to replace?
Is the internal vaporating unit. close to it?(i'd like to clean it)
  • 4313
  • 167
Re: tHERMOSTAT of Air Conditioning sys.
« Reply #1 on: August 19, 2010, 06:58:39 AM »
There is a thermistor mounted in the evaporator housing that senses the air temperature and passes that information onto the a/c amplifier which will stop & start the a/c compressor as required.  Physically it will be located in the evaporator housing under the passenger side dashboard, either behind or below the glove box.
Please be aware that there are many factors that can impact how long the compressor runs - and can cause it to run continuously.  In fact, anything that prevents the air temperature in the evaporator housing from getting low enough to turn it off - outdoor air temperature is the single biggest factor - on a hot day the compressor will run longer, the a/c controls also have an impact - if you're set to draw fresh air in, the unit pulls the warm air in from outside and the compressor will also run longer and quite possibly, continuously - make sure that when you slide the lever to close the air intake, the intake actually closes, sometimes the cables between the lever and the flap come loose.
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
Offline rbeny
« Reply #2 on: August 22, 2010, 01:16:53 PM »
1. Thanks for the exelent info.
2. I'm using the "Suzuki Haynes Repair Manual",for fixing any bugs.
    On this case ,I didn't find any relation to "Thermostat", but ,he is talking about "Air condition and Heater control ass"(p.p 3-12). Does this refer to "Thermostat"?. Can u assit me with some details for recogizing the Thermostat?.
3. My a/c expert said that there is a great chance that the A/C  radiator ia fulll with dirt inside.
    Does radiator cleanung need a high level of A/C experience??Special tools? (Nothing about it in Haynes Manual!!)
