dumb samurai question
  • 11 Replies
  • 4179 Views
Offline v-stone
  • 625
« on: August 17, 2010, 10:09:50 PM »
I shorted out the battery while tightening down the cables and now I get nothing at the ignition. I've looked at the fuses in the brown box located above the clutch pedal and they are all good. Battery tests at 12.8 volts. What could this be???
SAS Tracker! No looking back now.
Re: dumb samurai question
« Reply #1 on: August 17, 2010, 11:26:06 PM »
Sounds like you popped the big Maxi fuse next to the battery,
should be like a 60 Amp, or a 50 ??? but check there
Offline v-stone
  • 625
« Reply #2 on: August 18, 2010, 06:31:20 PM »
I don't see any fuses next to the battery. This is an 86 samurai. Am I missing them?
« Reply #3 on: August 18, 2010, 07:54:18 PM »
Cool side draft carb setup. Sorry I was thinking of the cover by my battery,
there must be a spot where the power from the battery goes, look there,
should be a smaller wire, and that's what supplies the power for the inside
of the truck, including the starting circuit
Offline v-stone
  • 625
« Reply #4 on: August 18, 2010, 10:45:22 PM »
Thanks. The small positive wire from the battery was spliced 2 times and one of them came loose.
The side draft carb was running great for the first day but now I can't get it to do more than sputter and die. The saga continues.
« Reply #5 on: August 18, 2010, 11:02:40 PM »
Don't get me started on carbs..... they drive me nuts!
« Reply #6 on: August 18, 2010, 11:03:43 PM »
What kind of carb is that?
You might want to check the fuel pressure, and fix that stick that
you have put into one of those the fuel lines  ;)
« Reply #7 on: August 19, 2010, 02:57:46 AM »
Surely only a Harley would have an eagle on the top cover.
I'd check for air leaks where the adapter bolts to the manifold. You may need some kind of heater on that adapter come the winter, that kind of adapter is notorious for carb icing.
Offline jow003
  • 403
« Reply #8 on: August 19, 2010, 06:01:21 AM »
what year is your samurai?
BUY MY STUFF!! pm for details
87 Samurai...
5" SPOA/OTT -RRO
1.5" leaf springs-OME
RUF conversion-Trail Tough
1" shackles
33x1250x15 MTZs
15x8- DC-2s
« Reply #9 on: August 19, 2010, 08:11:35 AM »
Harley was my first thought but not having one to look at, or knowing
anyone with a Harley I didn't know for sure
Offline v-stone
  • 625
« Reply #10 on: August 19, 2010, 11:48:11 AM »
Its a 40mm CV carb from a Harley. Picked it up on ebay for $65.
Is there a way to test the fuel pressure to get exact numbers? I had a filter on it that has a bypass to keep fual pressure at 3 psi.
The stick is plugging a vacuum line that is no longer needed. I will replace it with a cap after I figure out why its not starting. The first day with the carb it ran great, now it just sputters.
Offline Zuki-Girl
  • 128
« Reply #11 on: August 19, 2010, 07:41:45 PM »
That's why I went with a 1.6 8 valve TBI.
