diff housing sheared in two
  • 1589 Views
Offline zeabutizillie
  • 9
  • 1994 tracker lsi 3 3 calmini , 31's, cal stabalize
« on: August 15, 2010, 12:27:01 AM »
solutions?  anyone else had this happen. 3+3 calmini lift
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: diff housing sheared in two
« Reply #1 on: August 15, 2010, 09:05:21 AM »
TracKick?  Samurai?
I'll assume it is a TracKick...
The aluminum thirds are notorious for failing when you hammer them on the trail.
Your choices are:
Drive gently.
Keep a spare third handy.
Find a steel GV third member and swap out the guts.
or visit this page:
http://www.zukiworld.com/month_090103/feature_sidekickdrivetrainimprovements.htm
Some of the best TracKick wrenching articles can be found right here at Zukiworld.com!
Ack
  • 9
« Reply #2 on: August 15, 2010, 10:40:08 AM »
thank you or the information. yes it is a tracker.  I don't like to take it easy that is for sure.  Has anyone bought the calmini diff housing?
« Reply #3 on: August 15, 2010, 10:58:56 AM »
It's not the diff housing that usually breaks, it's the 3rd member, so
go get you a steel GV front 3rd and you should be good.
I've only broke 1 front 3rd, and that is from backing up a boulder, you
should be able to replace your 3rd with another of the same and put
a collar on it, one of the members, I think Mud Child??? is making them
and seems to be abusing it well with no problems
  • 9
« Reply #4 on: August 15, 2010, 03:00:02 PM »
how does the collar work does it involve welding?
« Reply #5 on: August 15, 2010, 05:17:03 PM »
No, it's a bolt on ring that helps to even the pressure on the
3rd to both sides of the snout so it doesn't twist and split open.
It bolts to the cross member that the 3rd rides on, you might need
to drill a hole or two to put bolts in tho
