be4 i buy.. do you like your OTT OTS steering
  • 2114 Views
« on: July 21, 2010, 08:32:32 PM »
just looking to replace my entire steering system (no power steering at this time :( later tho)  just wanted to know how other owners like their OTT or OTS as their called.  the whole steering system above the axle...  or a few pointers.
thanks
Re: be4 i buy.. do you like your OTT OTS steering
« Reply #1 on: July 21, 2010, 10:16:35 PM »
I run half of the OTT steering, just the passenger side.  Works great and I have never had any bump steer.  :)
Offline grats
  • 28
« Reply #2 on: July 22, 2010, 08:25:18 AM »
Hey Drone367, is that OTT on your 410, if so where and how doe's it connect. I've been told that because
I have drum brakes up front that any OTT system won't work. Sorry to hi-jack this thread.
1982 SJ410
1997 Tracker
2008 SX4
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #3 on: July 22, 2010, 09:11:09 AM »
thanks
I have a Rocky Road full OTT the I picked off a salvaged truck.  It eliminated bumpsteer on my 4.5 SPOA lift - which is why I installed it.  If you plan to drive your truck daily on the highway, it will be an awesome improvement - well worth the investment!  BTW:  Either a full or "Stage One"  OTT will do this.  The full OTT simply moves the tierod up over the axle for clearance purposes.
Check this out:
http://www.acksfaq.com/bumpsteer_explained.htm
Ack
« Reply #4 on: July 22, 2010, 03:49:02 PM »
I am running Samurai axles on my SJ-410, but you should be able to swap your front drums out for the disk brakes on the 84 SJ-410.  I believe everything from the knuckles out are exchangeable between the 410 axles and the SJ-413/Samurai.  But that may have been due to my previous set being an 84 that came through Canada.
Offline jow003
  • 403
« Reply #5 on: July 27, 2010, 06:50:24 AM »
i got my OTT from Rocky Road, DO NOT MAKE MY MISTAKE  if you end up gettin OTT go to Low range
BUY MY STUFF!! pm for details
87 Samurai...
5" SPOA/OTT -RRO
1.5" leaf springs-OME
RUF conversion-Trail Tough
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Offline mrhawk
  • 130
  • I Love ZUKS
« Reply #6 on: July 28, 2010, 04:19:19 AM »
I run the mercedes arm, half high steer, very happy with it.
No bump steer and stock ackerman makes it drive great.
« Reply #7 on: July 30, 2010, 12:02:27 PM »
well just but my order in today..
6 inch YJ lift
new clutch
needed to rebuild my trans so got the parts with new input shaft throwout bearing and ect.
front knuckle rebuild kit
new Sky OTS steering
4.57 ring and pinion with diff rebuild kit
shrockworks front bumper
and other goodies
we'll see how this all comes together.  i'll be sure to start a build post once i get started.
thanks for all the advice
