Help w/ Sami Steering Alignment Requested
  • 1144 Views
« on: July 11, 2010, 08:49:29 AM »
I am new to Samurai (former Jeep owner for 38 years) and am rebuilding am '87 Sami SE I acquired. Before disassembling the vehicle for engine rebuild and paint ( front clip, engine, trans, doors, windshield, roll hoop removed) , I noticed that the steering wheel was off-center going straight, and there was excessive play in the wheel. There is no "pull" to either side, and the Sami will track straight, albeit with the play mentioned.
I did a "Search" but didn't see anything relevant-
By centering the steering wheel (1/2 lock-to-lock position which corresponds to proper steering wheel position for straight ahead), there is NO play (since the steering sector on worm boxes are normally cut tight in the center, and with play on either side). This is as it SHOULD be, and my Sami box is perfect in this regard.
The problem is that with the steering wheel straight (sector centered on worm gear), the front tires are turned slightly to the right, meaning to make the Sami go straight, one must hold the wheel slightly left, resulting in the play described (since the steering is no longer at the center of the steering worm). This is with the toe set properly (there is no abnormal tire wear), BTW.
Since the only adjustment is toe on one side, there is no way to set both front wheels straight with the steering wheel straight.
The only ways I can see to accomplish an aligned steering wheel are:
1) Reposition the Pitman arm on the steering gear one tooth off to hopefully recenter the tie rod (assuming the splines will allow this) w/ the steering wheel positioned straight ahead, or
2) Loosen the "U" bolts securing the front axle to the springs, and slightly repositioning the entire front axle to one side slightly (probably by less than 1/4"), causing the wheels to be straight ahead w/ the steering box/wheel centered. I am not sure this is physically possible, either, if there are locating pins or tabs to hold the axle in position.
Failing 1) or 2) (above) are there tie rods, or Pitman arm-to-tie-rod steering rod assemblies available that have adjustments possible as with virtually every other 4WD vehicle I have owned?
Surely Suzuki cannot think that adjustment will never be required on a vehicle intended to rough service as is the Sami. I am not aware of any frame damage (nor is any evident), BTW.
Thanks-
Bob
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
Re: Help w/ Sami Steering Alignment Requested
« Reply #1 on: July 12, 2010, 05:48:43 AM »
assuming all stock:
center wheels, and the adjust toe in to 1/8"
pull steering wheel and set to straight.
job done.
« Reply #2 on: July 13, 2010, 11:17:39 PM »
assuming all stock:
job done.
I hesitated to remove the 1/4th turn misaligned steering wheel since 90 degrees put the sector in the wider portion of the worm, leaving excessive play.
We put the car back on the lift today and I noticed that the front spring shackles were bent as if the car had plowed into something w/ the front wheels turned, causing the shackles to be bent from vertical.
We straightened the shackles, and that repositioned the axle laterally enough that the steering wheel was only one spline off perfectly horizontal. I removed the wheel and repositioned it because that close to centered doesn't introduce much play in a properly adjusted box. I have about 1/2" play centered now (and might be able to remove a tad of that w/ the box adjustment), and the Sami tracks perfectly straight now.
All's now right with the World again!
Bob
(If I'd have ended up w/ more than one spline off, I'd have repositioned the pitman arm on the steering sector shaft to preclude excess play. I even pulled the arm off the box, and I can tell you it was TIGHT)
