5:14-1 calmini t-case loud
  • 1608 Views
Offline pllssmith
« on: July 06, 2010, 06:36:58 PM »
I HAVE CALMINI 5:14-1 GEARS IN MY T-CASE AND ONCE I GET TO 45 MPH IT STARTS GETTING A HIGH PITCH WINDING NOISE. AND IN 4WL IT GETS LOUD AT HIGH RPMS. I PUT ALL NEW BEARINGS IN CASE AND ITS ALWAYS BEEN THAT AWAY ALSO IVE CHANGED THE GEAR OIL 2 TIMES NOW ITS GOOD AND CLEAN NO METAL SHAVINGS. AND NOW IM TRYING LUCAS GEAR OIL AND ITS NOT HELPING NEITHER. ANY BODY HAVE ANY IDEAS?
Paul S.
Re: 5:14-1 calmini t-case loud
« Reply #1 on: July 06, 2010, 09:11:57 PM »
Sounds like a miss machined set of gears, they should make
some noise, but not as loud as you are describing
« Reply #2 on: July 08, 2010, 05:24:24 AM »
+1  the amount of angle intersection of the gear is crucial.  They will howl every time if not lined up just perfect.
Offline mrhawk
  • 130
  • I Love ZUKS
« Reply #3 on: July 12, 2010, 01:28:10 PM »
Same problem with my calmini gears. when I hit 60 the high pitch whine is brain piercing.  :(
« Reply #4 on: July 12, 2010, 02:24:32 PM »
I've got Calmini gears in my tracker tcase and they're noisy, but only in 4wd.
« Reply #5 on: July 12, 2010, 05:54:42 PM »
Have you tried giving Calmini a call?
« Reply #6 on: July 12, 2010, 06:09:43 PM »
I hate to say this but I'm glad I got Trial Tough gears for the Sidekick,
they are quiet like they should be, sure there is a little noise but I never
thought it was loud or even abnormal, low gears make a little more noise
just from being low
