Suzuki Grand Vitara, Vitara, Chevy Tracker (Gen. 2 Platform) 1999-2005
(Moderator:
ebewley
Rocky Road Body Lift
richterll
11
June 29, 2010, 12:59:11 PM »
How does the RR body lift hold up? I have their spring spacers on my 2005 4door GV now, and they have collapsed to almost no lift. Wonder if the body lift works better. Thanks in advance.
Last Edit: June 29, 2010, 01:05:27 PM by richterll
2005 GV
2 in lift
MUD CHILD
355
9
Re: Rocky Road Body Lift
June 29, 2010, 01:37:13 PM »
What type of spring spacers did you use? Here is a picture of the lift kit I make that will fit your truck. The spacers are made from billet aluminum and will not collapse over time. I would recomend staying away from bodylifts for a couple reasons but the obvious one being that a suspension lift raises your complete truck up which increases ground clearance where a body lift only moves the body up off the frame.
NO DITCH TO DEEP NO HILL TO STEEP
http://srcustoms.ca/
bzzr2
1011
3
July 09, 2010, 10:27:19 AM »
their body lift is solid, have had mine 4yrs and wheel regularly. their spacers are crap, mud child's look nice and suspension is better than body lift.
09 taco reg cab short box 4x4
Canazuk
19
Reply #3 on:
July 09, 2010, 11:00:16 PM »
I have clocked 5000k on my kit from mud child, works great only issue is that it keeps getting covered with mud? haha
nprecon
2318
52
ONWARD... through the fog!
Reply #4 on:
July 10, 2010, 08:44:15 AM »
OBTW as your RR coil spacers gradually compressed to 1/8" your front alignment changed significantly and now you are probably wearing the inner edges of your front tires excessively unless you have continually returned for an alignment. This is another great selling point to the coil spacers like mudchild's or Jeff Hoepker's.... they don't collapse. Once they "settle in" you are good and your truck will hold an alignment and you get more miles from your tires.
'02 Chezuki Tracker with a 2 Liter and 5spd. It works for me!!!
richterll
11
Reply #5 on:
July 10, 2010, 06:52:14 PM »
Thanks all,
I have Jeff's kit waiting to go on next week. I'm considering a 1 or 2 inch body lift, and was wondering how the RR lift worked considering the dismal results with their spring spacers.
2005 GV
2 in lift
Canazuk
19
Reply #6 on:
July 10, 2010, 11:48:33 PM »
Most body lifts are the same brand that people rename as there own, I got a Zukination one that came with the copy and paste Sky instructions. I asked him about it and he said out right it was the sky kit. Seeing how RR has a 2" lift it is more then likely the sky kit which has the same blocks as 95% of all body lifts for all trucks
http://zoneoffroad.com/product-acc?ki=91&gr=
here are the zone ones straight from china, or you could get the masterkit1 body lift but their stuff looks like some kids in grade 10 metal work designed and made it
http://cgi.ebay.ca/Suzuki-Vitara-XL-7-Tracker-1999-05-Body-Lift-2-/230458812984?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item35a86a6a38
I also own an ark welded and a can of trim clad I should start selling lifts
Last Edit: July 10, 2010, 11:50:33 PM by Canazuk
bzzr2
1011
3
Reply #7 on:
July 15, 2010, 08:00:34 PM »
RR is also from sky i believe, never had a problem with it. be sure to extend the steering.
