Turning and hiting a bump noise
  • 1345 Views
Offline RACER X
  • 383
  • zuki or die!
« on: June 27, 2010, 09:41:14 PM »
If I turn and hit a small bump at the same time I get a clunk/poping noise from the front drivers side of my 98 kick Im leaning towards cv joint anybody got this prob or better yet an answer?
98 kick
Offline beagle..t
  • 1239
  • 16
Re: Turning and hiting a bump noise
« Reply #1 on: June 28, 2010, 07:43:20 PM »
frnt sway bar
Offline RACER X
  • 383
  • zuki or die!
« Reply #2 on: June 29, 2010, 11:52:28 PM »
sway bar is disconnected up front
98 kick
Offline TNTracker
  • 37
« Reply #3 on: June 30, 2010, 06:44:16 PM »
I had one doing close to the same thing dont know for sure what yours sounds like, and about 6 months later the strut started leaking oil out around the piston. I got rid of it before i changed the strut but i am guessing thats what was causing it. All the ones ive had with bad cvs didn't make much noise until i put them in 4 wheel drive but i guess its possible, but you would think it would do it every time you turned even if you didn't hit a bump if it was a bad cv.  ???
Offline RACER X
  • 383
  • zuki or die!
« Reply #4 on: July 03, 2010, 09:03:31 PM »
Hey thanks for the input anyone else got any ideas
98 kick
« Reply #5 on: July 04, 2010, 08:49:12 AM »
What tires do you have?
Did you take the sway bar off or just loose?
Check the upper strut mounts for damage, I had one come
apart once, now I carry a spare
