vitara & tracker brakes
  • 1577 Views
Offline zukin
  • 54
« on: June 26, 2010, 07:16:50 AM »
from what  I have read most vitaras have 16" wheels and most trackers have 15" wheels.
so I am guessing the vitara has larger calipers and rotors, are they interchangeable with the tracker?
Offline Crazy4x4
  • 42
Re: vitara & tracker brakes
« Reply #1 on: June 26, 2010, 07:50:58 AM »
Easiest way to check is go to www.autozone.com and see if both vehicles have the same part numbers.
Finally a 4low on a small SUV with GREAT MPG!!!!
2001 Grand Vitara 4x4 2.5LV6 Auto
1993 Dakota 4x4 5.9 V8 33in rear locker 10,000Lb winch TONS more!
Offline TNTracker
  • 37
« Reply #2 on: June 27, 2010, 05:29:01 PM »
They are different. I almost changed all my Vitara brakes to the Tracker rotors and calipers to keep from having to run 16" wheels, but i just added enough lift to clear 245/75 r16 tires. You can't find many tires any smaller than that with an aggressive tread was the main reason i wanted 15" wheels.
Offline zukin
  • 54
« Reply #3 on: June 28, 2010, 05:45:44 AM »
does that mean you can swap calipers and rotors from tracker to vitara or vise versa?
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
« Reply #4 on: June 28, 2010, 06:06:13 AM »
Even then you will have a hard time finding 15" rims that fit. The rims on the "99+ Trackers seem to be special made or something because the 15" rims factory and aftermarket from my "97 Tracker did not fit on my "00 2.0 2-dr or my "04 2.5 4-dr. They hit the calipers.
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #5 on: July 03, 2010, 07:28:54 AM »
I have a set of the 6-spoke aluminum rims from a '95 Kick on my '02 Tracker.  There were no problems with fit at all.
Offline Canazuk
  • 19
« Reply #6 on: July 06, 2010, 06:48:30 PM »
I had to run wheel spacers on my after marker 15" rims to clear the brakes on my tracker, but the factory ones were 15"
Offline Jeff@TireBalls
  • 559
« Reply #7 on: July 06, 2010, 07:21:03 PM »
Yes
2000 Grand Vitara Limited, 2" lift, 225/75-16 BFG KO's, 5.12 gears, Safari snorkel, roof rack.
1987 Samurai LWB, VW 1.9 Turbo Diesel.
