WTB: Wheels and Tires
  • 1895 Views
Offline TNTracker
  • 37
« on: June 25, 2010, 09:03:43 AM »
Looking for a set of 15x8 black spoke wheels 5x5 1/2 bolt pattern with 30x9.5 mud tires with at least 50% tread or better. If you have either or both for sale let me know.
Offline jow003
  • 403
Re: WTB: Wheels and Tires
« Reply #1 on: June 25, 2010, 09:28:47 AM »
i got stock white wagons 15x7 and 29x850s.  i know its smaller all the way around by a little but they still have a ton of tread
BUY MY STUFF!! pm for details
87 Samurai...
5" SPOA/OTT -RRO
1.5" leaf springs-OME
RUF conversion-Trail Tough
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Offline TNTracker
  • 37
« Reply #2 on: June 25, 2010, 01:10:03 PM »
What brand are the tires?
Offline jow003
  • 403
« Reply #3 on: June 25, 2010, 02:15:56 PM »
haha sorry, bias ply TSLs
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Offline TNTracker
  • 37
« Reply #4 on: June 25, 2010, 04:28:10 PM »
You got a PM.
Offline ncspack7civic
  • 108
« Reply #5 on: June 27, 2010, 03:07:53 PM »
Im in the same boat. Im looking for the same set up!
Offline TNTracker
  • 37
« Reply #6 on: June 28, 2010, 06:28:48 AM »
I found a set of 31s maxxis buckshots that have maybe 300 miles on them cheap, but i dont know how much rub i will have only running 2" coil spacers. I dont mind to cut alittle but i dont want to hack half the fender off either. I had a set on my Vitara but i also had a 2" bodylift. I hate to buy another new set because everytime i do i end up selling whatever i but them on a few months later.
« Reply #7 on: July 03, 2010, 07:40:32 AM »
I have 31-10.5 all terrains with 2 inch coil spacers and they fit great all I had to trim was the metal lip inside the fender that goes on the firewall I cut that flat about half way up and just welded it flat because they have pinch welds on the part I cut off and on the fender i cut from the front lower fender bolt to the outside of the fender at an angle so you can't see the cut at all from the outside and the back is fine, but It all depends on your offset of the wheels mine just work out when I flex they tuck perfectly in the back. hope this helps
