1-remove shifters
2-remove both F & R driveshafts(mark them for alignment)
3-block the motor as stated above, remove the starter
4-loosen the bolts from crossmember to trans and motor to trans/transfer
5-jack the trans/transfer up a smig (smig is a technical term
![Wink ;)](https://www.zukiworld.com/forum/Smileys/aaron/wink.gif)
6-remove crossmember, all bolts and slider her back
7-let her down a lil bit, unplug wires then take it the rest of the way down.
i have found that having the car seculy jacked up really high helps in the garage, and just remove the 2 bolts holder the starter to the bell housing and sort of hang the starter there, you dont have to unplug it (make sure your battery is unhooked!)
if you have done a few you will find this really straight forward, it is simple and pretty light. good luck
![Smiley :)](https://www.zukiworld.com/forum/Smileys/aaron/smiley.gif)
