tires
  • 1623 Views
Offline TX-Trak
tires
« on: June 24, 2010, 08:36:24 AM »
Will 235/75/R15 tires fit on stock tracker rims?
95 tracker manual 4x4
02 Dakota Quad Cab
Re: tires
« Reply #1 on: June 24, 2010, 08:40:31 AM »
Yes, and they look better than the 205 stockers
Offline TX-Trak
Re: tires
« Reply #2 on: June 24, 2010, 08:54:37 AM »
will i need to lift before i can put on the 237/75/R15 tires, if so, what do you suggest body or suspension?  my long term plan is to eventually put a 2" body, and a 2" suspension.  Just not sure which i'll do first.
02 Dakota Quad Cab
Re: tires
« Reply #3 on: June 25, 2010, 01:33:02 AM »
You might have to trim the bumper a little bit on the bottom, but they should fit on just fine.
Offline mike5721947
  • 545
Re: tires
« Reply #4 on: June 25, 2010, 06:10:00 AM »
i had 235's on mine when it had no lift, only rubbed on the rear of the front wheel well on the frame, this is at FULL turn, if you stay off a 1/16 of a turn of the wheel it doesnt rub. i didnt adjust my steering stops as it wasnt enough to bother me. the frame doesnt cut the tire at all, just rubs and makes a bit of noise.
once you get 2 inches of lift on they really start doing well. makes alot more room in the wheel wells. i have 3 inches of lift and 31's stuff up nicely.
31" kumhos 3inchs of lift.
Offline woof359
  • 111
Re: tires
« Reply #5 on: June 25, 2010, 01:44:44 PM »
I JUST MOUNTED 235 75 15 TIRES WITH 8x15 RIMS, FRT TIRES RUBBED FRONT BUMPER BAD. AFTER CALMINI RESERSE SHACKLES AND THAT GAVE MY SAM A 2.5 LIFT THERE JUST FINE
CHUCK AND MICHELLE
