Grille Guard needed for 03 tracker
  • 21 Replies
  • 4285 Views
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: Grille Guard needed for 03 tracker
« Reply #15 on: September 14, 2010, 06:48:03 PM »
It took an extra person to get the brush guard into position.  Thankfully my neighbor Lonnie stopped by and lended a hand.  I unscrewed the chrome piece out of my grill and I am stripping the chrome off of it.  I had a small section that was de-laminating and it looked like crap so I will either remove the balance of the chrome and paint it flat black or I will go to the bone yard and find a replacement.  Anyway, we got the brush guard mounted just as darkness caught up with us.  Again, one photo below needs to be rotated counter-clockwise.  Don't know what the deal is, but there it is.  I took it out for a drive in the darkness to see how much the brush guard reduced my headlight beam.  It appears to be negligible.
« Last Edit: September 14, 2010, 07:34:48 PM by nprecon »
Offline nprecon
  • 2318
  • 52
« Reply #16 on: September 15, 2010, 03:23:28 PM »
Was able to adjust the brush guard a little today.  I tilted it backwards about one inch which leveled it out better with the hood.  I  painted it flat black and then completed the grill insert mod and called it good.
« Last Edit: September 15, 2010, 04:23:02 PM by nprecon »
Offline Crazy4x4
  • 42
« Reply #17 on: September 16, 2010, 12:24:11 AM »
Looks like it fits good!
Finally a 4low on a small SUV with GREAT MPG!!!!
2001 Grand Vitara 4x4 2.5LV6 Auto
1993 Dakota 4x4 5.9 V8 33in rear locker 10,000Lb winch TONS more!
Offline tcfootball
  • 82
« Reply #18 on: September 16, 2010, 10:49:20 AM »
Nice job.  Looks real good.
Offline nprecon
  • 2318
  • 52
« Reply #19 on: September 16, 2010, 11:59:23 AM »
Thank you much.
« Reply #20 on: September 16, 2010, 10:27:19 PM »
Fits so good, it looks like it grew there. ;)
`00 2D 2.0L Auto Tracker, Jeff1997's 2" Coil Lift, Mudchild's 2" Body Lift and 31x10.5R15 General Grabber Competition Tires
Offline nprecon
  • 2318
  • 52
« Reply #21 on: September 20, 2010, 04:01:24 PM »
Oh yeah, and I got tired of the aluminum rims that I had on Buster so I went to my local "man mall" (junkyard) and found 5 steelie stock rims from a '96-'98 Tracker, cleaned them up then sanded them down, wiped them down with Xylol then painted them semi-gloss black and ended up with an inexpensive set of black steelie rims to mount my Courser AT2s on. The AT2s have a solid tread strip down the center which reduces the road rumble the straight Courser ATs had quite bit more.  I have just a very slight rumble when cruising down the highway.  Barely noticeable.
« Last Edit: September 20, 2010, 04:06:20 PM by nprecon »
